Tailor made ECU data converter supporting Futaba and ProJet-3 ECU´s
We have exiting news for Futaba customer using turbines with ProJet-3 ECU´s
Our new Pro-FEPC + IAS ECU data converter Firmware Version 1.0
The Pro-FEPC is a ECU data converter compatible with all ProJet-3 ECU´s (turbine list below).
It will sent the listed ECU meas values back to your Futaba TX via Sbus2 telemetry.
The +IAS version will give you in addition the airspeed measurement value.
The Pro-FEPC is based on the same hardware like our 1000 times proven FEPC for JetCat turbines.
It supports the so called “JetCat Display” inside the Futaba TX like T18MZ-WC or T18SZ.
Benefit and features:
Easy implementation, no PC is necessary! Plug and Play! Compatible to ProJet Hornet-3 ECU´s.
A real benefit for customer who own a ProJet "GAS-V1.0" modul too.
Tailor made support of the following turbines, will give you correct thrust and fuel flow displays.
BF Turbinen: BF100 und BF300
Hammer Turbinen: IQ90+, IQ130+, IQ140+, IQ170+, IQ180+, IQ190SS, IQ200+ u. IQ220+
Frank Turbine: FT160, FT180Raptor, FT220 und FT250
Behotec: JB130, JB165, JB180 und JB220
The following ECU measured values are transmitted to the receiver:
All the main important ECU values at a glance
There will be no change in setting up your ECU parameter. The operator can run the known EDT GSU terminal and the I/O board in parallel with the Pro-FEPC.Under the following links you will find more information and pictures:
http://www.cb-elektronics.com/pro-fepc---ias-v1.0.html
http://www.cb-elektronics.com/pro-fepc-v1.0.html
Best regards
Dirk
CB Elektronics
- RPM of the turbine (RPM)
- IAS airspeed (km/h or mph depending on you transmitter setting, (only Pro-FEPC + IAS version, ProJet Gas-1 module necessary)
- EGT temperatur (°C/)
- Pump voltage with „Armed Alarm“ (fast Flame-Out warning)
- Thrust in Newton (N), in relation to the above turbines
- Tank volume (mL) alarm will be set in the Futaba transmitter (TX)
- Kerosine / FuelFlow (mL/min.) in relation to the above turbines
- Stick position in %
- ECU turbine battery voltage
- Turbinen status display in relation of the Projet Hornet-3 ECU vs. Futaba „JetCat V10“ display field
Best regards
Dirk
CB Elektronics
