New Sport Jet: T-One Models Mini Fortune / Mini T1
#301
I’m running a K85 in mine. I flew mine three more times today. Ive got 20+ flights on it and l’m consistently only using about 200’ of the runway to land to full stop. Takeoff is about the same, about 200’ to rotate. Mine weights just under 21 lbs full of fuel.
#302
I'm joining the club! I ordered my entire setup yesterday. Black/Yellow scheme, K-85G2, Cortex, Savox SV1250MG servo pack, wiring harness and more. I just don't know how I'm going to wait two months for the air frame. This is my first turbine, but luckily I have a great mentor at my club!
#303
My Feedback: (46)
I finally ordered mine tonight got the red and white scheme. I talked to my buddy who’s a jet guy about it and getting my waiver which should be no problem, the JOK sale finally got me to order. Now the waiting begins...
I ordered the airframe and the wing/fuse bags but held off on the servos for now. What are the thoughts on the Savox 1250MG’s that pacific jets offers? I will order the wiring kit for it in a couple weeks.
Pretty exciting, I flown just about every other type of plane out there but this will be my first jet.
#304
Pretty exciting, I flown just about ever other type of plane out there but this will be my first jet.
I've flown Savox servos in my TRex 600 for years. The jet guys at my club (RocketCityRC) fly Savox in some of their jets and highly recommend them. You can't beat the price on the pack that Pacific sells for the Mini (not that I'm suggesting that you be cheap).
#305
My Feedback: (46)
Congrats on your purchase! We'll see who's gets here first.
The hardest part for me so far was deciding on the color scheme, too many to choose from!
Is there no manual online for this plane? What size servo arms do i need? Also the linkages shown in DepecheModes pic are those what’s included or are those aftermarket?
#306
Thanks, congrats to you too! Looks like quite a few people on this thread are using the 1250’s as well. I’ve used a couple different Savox in the past as throttle servos for a couple giant scale 3D planes with good results. The price is definitely right!
Hope that helps
Stock linkage
#307
#310
My Feedback: (46)
I usually run aluminum arms on everything, looked like he was using aluminum arms, sorry I’m used to the 3D world.
Does it come with a UAT or do I need to buy one, size? I want to have everything here and ready to go when the plane gets here so I’m putting a list together. Usually i just look at the manual ahead of time, but there isn‘t or I can’t find a manual.
#311
MPJETS is a JET hardware company.
I may try the one on top so that I don't have to use safety wire....maybe
#312
#317
I'm looking at Aluminum servo arms for the Savox 1250MG in this jet. How long do they need to be? My LHS has the Savox SH-82 arms in stock (25T 38mm long).
...still more posts before I can include URLs.
#318
I just used the plastic servo arms that came with the 1250 servos, they work fine.
#320
I've got everything but the airframe now.
- K85G2 w/ FOD screen
- Radio system components
- UAT 150cc
- Cortex
- Wiring harness
- Servos
- 3s and 2s LiFe packs
- Kingtech Oil
- ...and other assorted bits and pieces.
#322
Mine fly's AWESOME with the K-85. Tons of power and great flight times. I built it with this also:
https://www.amazon.com/gp/product/B00FS6CIA6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Make sure to end the servo extension at the Horizontal and Vertical stabilizers in case you ever need to replace a servo, (Don't put the connection down next to the pipe). It is easy to keep tight and make sure it cannot ever touch the pipe. It really is a very simple build.
#323
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Make sure to out the servo extension at the Horizontal and vertical stabilizers in case you ever need to replace a servo. It is easy to keep tight and make sure it cannot ever touch the pipe. It really is a very simple build.
cheers
#324
<---Amazon Link to heat shield loom--->
I think he means to have the servo extension connector outside the pipe area (in the tail and horizontal stab).
P.S. It's such a pain in the butt with the URL prohibited stuff for n00bs!
#325
