Reload this Page >
CARF Joker build thread
Old 11-11-2018, 05:43 AM
  #476
Dave Wilshere
Danny
What is the wing in the roof of your workshop off?
Dave
Old 11-11-2018, 08:33 AM
  #477
F1 Rocket
The wings are from a stillborn full scale project from 20 years ago. They would have gone on a 125% Monocoupe powered by an MP-14 radial. Got as far as you see and then the whole project collapsed into a shouting match between the companies involved. Just never could bring myself to cut them up and bin them so they hang in the shop.
Danny
Old 11-12-2018, 06:04 PM
  #478
kevin
F1 rocket... Thanks for the spring idea. I had the nose gear door mounted but hadn't yet figured out how I wanted to have it close.
I mounted the spring to two modified 1/2a control horns which I eventually screwed to the gear door and nose cone former. My gear door just rides on the strut directly but I did add 3M clear bra sheet to the back of the gear door so the metal strut doesn't rub directly against the carbon door.
Old 11-17-2018, 11:01 PM
  #479
kevin
I have seen a few guys run their fuel line from the pump to the turbine on top of the main fuel tank. Any issues doing this? Im guessing the pump is plenty strong to pump from the fuse floor to the top of the tank and back to the turbine or we would have heard from them otherwise. Thoughts?
Old 11-18-2018, 12:40 AM
  #480
Midas D.
I run it like that, the filter is in between the 2 wooden formers witch hold the tank.
No problem at all.
Cheers,
Ed
Old 11-18-2018, 08:56 AM
  #481
Dave Wilshere
Pump will lift fuel over 1m happily ��
Old 11-25-2018, 05:56 AM
  #482
Dave Wilshere
Out today with the Joker, fits in my van assembled, so great grab and go model. Overcast and grey day, couple of flights and back to the warm :-)
P-100 is perfect power for this airframe, low residual thrust helps slow touch downs on our 360' grass strip.
Old 11-25-2018, 08:59 AM
  #483
Bob_B
Bob_B's Avatar
nice pics DW
Old 12-02-2018, 11:41 AM
  #484
Dave Wilshere
Had the Joker out again today, perfect model for drizzly overcast days where it comes from my van assembled.
Old 12-07-2018, 06:56 AM
  #485
ltc
Default Green light on nose gear?
Hi,
When I watched the video of this maiden flight, I thought it looked like the green LED on the nose gear strut would turn on/off or change green to white during final.
Almost like it was a speed indicator?
Has anyone ever seen anything like this or know the pilot?
Old 12-07-2018, 12:57 PM
  #486
dccatl
Originally Posted by Midas D.
Originally Posted by ltc
Hi,
That's my Joker. I'm using the Xicoy FC-1 flight computer with a pitot tube for airspeed. The FC-1 allows you to set up 4 LED alarms based on airspeed (blinking green, solid green, solid red, blinking red), I've found it very helpful in getting consistent landing approach speeds.
Old 12-07-2018, 01:33 PM
  #487
ltc
Hi,
Nice to meet you and Thank you very much.
Old 12-09-2018, 12:53 PM
  #488
kevin
Getting closer. Little at a time since there is no rush this time of year...
Old 12-09-2018, 04:14 PM
  #489
skymaster68
Very Nice set up!!
Old 12-10-2018, 11:23 AM
  #490
cmjets
cmjets's Avatar
Hi Friends, you can find in my website a Kevlar tank for Joker model:
https://cmjets.com/c-arf/193-joker-2l.html
Regards from Spain.
Carlos
Old 12-10-2018, 12:13 PM
  #491
Dave Wilshere
Carlos
Not sure why you made one the same capacity as the one provided with the kit. Making it 10% bigger might have opened the market more for you. The stock tank is super light too...
Old 12-11-2018, 06:45 AM
  #492
ltc
Put down a deposit on a white/red Joker last night. Container has left Thailand, routing thru Hong Kong to California (didn't know CARF had a US warehouse). Was able to get the free shipping holiday deal from a plane in this container shipment.
Should hopefully see the plane by the end of January.
Thanks to everyone in this thread !
Old 12-11-2018, 08:10 AM
  #493
Dave Wilshere
Dave
Old 12-11-2018, 02:16 PM
  #494
cmjets
cmjets's Avatar
Carlos
really the question not is if the original tank run perfect, I’m total sure that is perfect, but when you spend a lot of € in a Jet and try make a internal installation more nice possible, sure you will want a personalized Kevlat Tank, or not.
But if you want it, I’m the option !!!
BR.
Carlos
Old 12-11-2018, 05:13 PM
  #495
kevin
I emailed you a while back about this but have you reconsidered a larger than stock tank that fits the mount?
BR.
Carlos
Old 12-12-2018, 05:30 AM
  #496
cmjets
cmjets's Avatar
Hi Kevin, yes, I can make it bigger, but I need maximal dimensions, same diameter but longer, or square, that have more capacity with similar dimensions but more capacity.
Write me:
[email protected]
thanks
Carlos
CMJETS.COM
Old 12-12-2018, 09:55 AM
  #497
Dave Wilshere
The tank is in front of the balance, so you cannot go crazy, I added 25mm length to mine so 2.2lt I get 7 minutes with a P-100Rx
Old 12-17-2018, 01:56 PM
  #498
carfjoker
how many channels do I need to fly the joker ? ix12 with a 9 channel receiver work ?
Old 12-17-2018, 02:00 PM
  #499
Dansy
My Feedback: (53)
Dansy's Avatar
10 channels unless you combine
2ails, 2elev, 2flps, rud, thr, Gear, brake.....
Old 12-17-2018, 02:08 PM
  #500
Dave Wilshere
Put the flaps on a matchbox or Powerbox Micro Match and you are set
Dave
