Reload this Page >
Fei Bao F-15 Elevator Linkage
Old 02-17-2018, 05:55 PM
AAbdu
My Feedback: (18)
Default Fei Bao F-15 Elevator Linkage
I have an older Feibao F-15 (the 55 inch span one) that I am finishing. I have the older aluminum elevator linkage that i am not satisfied with. it is the single U-shaped unit with the control arm built onto it with a single set screw and two small ball bearings.
The problem is, no matter what I do, I can't get all of the play out of the linkage. In addition, if I grab the stab at the tip I can feel the play as it wiggles up and down.
The instructions show a much more substantial "cage" type design with two set screws and a LOT more support, but that did NOT come with my kit.
questions:
1. Is the upgraded elevator linkage available? If so, from whom do I order it?
2. Will that fit the original space without significant modification?
3. If the upgrade is not available is there a way to make the original small unit more positive? I don't want any play in those big heavy stabs.
I can attach pictures if it helps.
Thanks in advanced for any suggestions you might have.
​​​​​​​Anthony
Old 02-18-2018, 07:19 AM
BluFox
My Feedback: (10)
Default F-15 elevator linkage
Anthony,
Please send pictures of your current part which is in question. Also show how you have it mounted.
FB Jets is on Chinese Holiday thru 26 February. If you send pictures, I will forward and have solution for you.
Send pictures and additional questions to: [email protected]
Regards,
Eric Clapp
FeiBao Jets USA
A & E Jets USA
Old 02-23-2018, 07:01 AM
AAbdu
My Feedback: (18)
Pictures have been sent via email.
thank you
​​​​​​​Anthony
Old 02-23-2018, 07:33 AM
powerjets
Eric, how much are tip missiles for the feibao Rafale ?
