jeti voice command
I can see it now. You're on short final, spotter for the guy next to you tells his pilot "Looks great with the gear up" - hilarity ensues.
...even worse - spotter says: I think you may have an 'Engine Shut Down' and another jet shuts the engine down while it is taking off...
No thank you, I will stay away from voice command - anyway, it is extremely irritating to have all the electronic chatter in the pilot's box.
JanR
JanR
My Feedback: (7)
Pretty sure if you select BEEP instead of voice there is no stick shaker when the timer expires. If you REALLY want voice timer call out and no stick shaker edit TimerV.jsn and remove the stick shake when the timer expires. Unfortunately you'll need to repeat that process following a transmitter software update. Still , maybe the next upgrade will have a control to turn stick shake on/off in the timer menu. For now those are a couple of work arounds...
