A/D Mirage 2000 1/5 scale building thread
#82
My Feedback: (44)
IL
Finally I finished with all the painting and my picture at the bottom of the airplane now I’m going to work on the engine and then just setting up the airplane and I’m ready for a test flight in about two weeks , once I get my pipe from Joey.
#86
My Feedback: (44)
IL
Hello Tassos, Three things happened One my airplane was out of trim, it wanted to pitch to the left and at the same time as the airplane was turning left the cross wind at that time got more Intense and last one my control were in the high rate and very sensitive .
After that it flew perfect. I hope I find someone with a good camera and my next flight so I can post it it was saved by in an angel the angel that I have on the vertical and underneath the airplane. (Αρχάγγελος Μιχαήλ )
#87
Glad it worked out well..... and post some more pictures of your final build, cockpit, undercarriage, power distribution, it'd be good to share with the group.
Thanks, Tassos
Thanks, Tassos
#88
My Feedback: (44)
IL
Hello Jack I use that rust oleum spray cans from the shelf for the blue color I used a darker tone first and then I went with the lighter tone over it I will post pictures of my set up later .Here is a video for my lights.
#92
Hello!
I am looking for AD Mirage 2000 owners (or builders) who already mounted the large underwing fuel tanks.
I just received them and was looking for ideas for a safe mounting. Unfortunately the manual is not giving any suggestions on how to install.
Most sense would probably be to glue blind nuts into the wing an screw the tanks from underneath to rails / wings... ?
Edit: Also would like to know if the mounting rails and the tanks itself have a left or right. I am not really sure and cant really tell by trial fitting or eyesight...
Cheers
T
Cheers
T
