Xicoy - LG15 Gyro Controlled Brakes
#276
NJ
Yes, Not sure that's perfect yet either, still messing with it. I did move the brake channel on the receiver to aux 3 instead of the x plus channel, They seem better, but still cant seem to get them to come on gradually as the air brakes do on my other jets. when I roll up on the right leaver, Which is assigned to be for brakes, at a certain point you can here them snap, and they are dragging, but as I roll the lever up or back, the drag seems the same, until they snap off again. trying to get them to come on easy and get progressively stronger as I roll up on the leaver till the lock, Tried messing with travel control, but when it gets to low they don't come on at all,I cant seem to make that happen, asked previous owner if he pulled the magnets and he said he cant recall. I have another question that you or someone else may have the answer to, Watched Martin Pickering on you tub with the electron GS200, And in the video he mentions that you can Y harness the rudder and steering together, and not have gyro steering affect rudder on the ground, I would like to do this if possible. All my channels on the 12120 receiver are used up, and I would like to free up aux 5 which is the channel I am using for steering so that I can use that channel for a gain channel to power my igyro. Any body know how to do the Y harness thing so gyro steering wont have rudder influence? Whew, That a mouth full, sorry
#277
From the video, I'm not sure you can use the gyro assisted steering without affecting the rudder. Shouldn't make a difference as they are usually coupled on the ground anyway? When the gear is retracted, I'm assuming the gyro for steering is turned off in the controller so the rudder will operate normally but that's something you need to confirm.
#278
[QUOTE=Big Sky;12599866]Yes, Not sure that's perfect yet either, still messing with it. I did move the brake channel on the receiver to aux 3 instead of the x plus channel, They seem better, but still cant seem to get them to come on gradually as the air brakes do on my other jets. when I roll up on the right leaver, Which is assigned to be for brakes, at a certain point you can here them snap, and they are dragging, but as I roll the lever up or back, the drag seems the same, until they snap off again. trying to get them to come on easy and get progressively stronger as I roll up on the leaver till the lock, Tried messing with travel control, but when it gets to low they don't come on at all,I cant seem to make that happen, asked previous owner if he pulled the magnets and he said he cant recall. I have another question that you or someone else may have the answer to, Watched Martin Pickering on you tub with the electron GS200, And in the video he mentions that you can Y harness the rudder and steering together, and not have gyro steering affect rudder on the ground, I would like to do this if possible. All my channels on the 12120 receiver are used up, and I would like to free up aux 5 which is the channel I am using for steering so that I can use that channel for a gain channel to power my igyro. Any body know how to do the Y harness thing so gyro steering wont have rudder influence? Whew, That a mouth full, sorry[/
some Electric brakes (not electron) have static magnets to hold the brake disk until the electro magnetic overcomes the static magnet and applies the brake force. In order to fix this you have to remove the tiny little magnets from the wheel hub. You will not be able to get smooth proportional braking with the magnets installed. Based on your description of the snapping sound I’d bet you have electric brakes with the static magnets. -Tom
#279
NJ
[QUOTE=Tip22v;12599875]
Yes I do, There JP Gear and JP wheels and brakes
#281
NJ
Which gyro setting do I have to change in the controller to correct my steering gyro, when I push the nose right the steering goes right also the same when nose left, steering goes left, should be other way a round correct?
#282
To change the gyro effect direction reverse the gain to the negative. E.g. if the gain is 30, make it -30.
#287
It’s pretty much the same with the Electron GS-200, except you can’t adjust the cutoff amperage, it’s preset by electron to match your specific model of Electron retracts. Also, Electron wheels/brakes don’t have those annoying magnets to remove. -Tom
#289
Yes same unit. Have you watched the video? Very well explained.
https://www.youtube.com/watch?v=5nJzwbkBpKY&t=1511s
#291
My Feedback: (53)
So you know not all LG15 are open to adjust the cutoff amps......I got mine from Xicoy before Dirk had them, when they are sold with a retract set they are not adjustable...at least it was that way when I got mine.
#292
Good point The first one I bought was GS-200 that I got for my Electron retracts, I bought it from the Electron Website. The second one I bought was a LGC-15 and I bought that one from the Xicoy website (like you, this was well before Dirk carried them). I did not buy it with a set of gear, just bought it by itself. When I got the second one it was locked, could not change the amperage cutoff. So I reached out to Gaspar and he hooked me up with a file that I downloaded to the unit, which unlocked the Amperage Cutoff settings. The other two units I bought from Dirk, and they both came unlocked. Yes, if you buy one of these units as part of a package deal that includes retracts it will probably come preset to those landing gear. However, if you buy stand alone it should be unlocked. - Tom
#293
On a DX-18 Gen 2, with x-plus set on, channels 1-12 are fully proportional and 13-18 are Not. Most folks assign On/Off actions to channels 13-18. Personally, I like to keep the Gear Switch on Channel 5, even though it is On/Off. Then it is the same with all my other planes.
Also, with a PBox (e.g. Mercury SRS) to activate the upper channels in the PBox, one has to set the PBox's protocol to DSMX2 vs. DSMX. This activates all 18 channels in the Pbox.
#294
#295
I guess I was a bit too quick. Speed Killzzzzzzzzzz. I meant to say Cannels 1-12 are "Fully Proportional" and the rest are not "Fully Proportional" The resolution is in fact reduced on 13-18 which basically makes them only good for on and off functions. The Spektrum manuals clearly says not to use these channels for control surfaces.
#296
#297
NJ
I am trying to get brake assist when turning left or right. When I give right steering input the right brake grabs good, when I give left steering input, I get very little brake force on the left brake, any ideas ?
#299
Okay, so I have read this thread looking for information on the install of this unit. Thanks to all that have contributed, it was mostly uneventful. The problem with mine is, the until was delivered as if it was part of some set, I do not have the "motors" menu and therefore cannot adjust it for my JP gear. I have been in contact with Xicoy and they gave me a .txt file to add to the micro sd card to unlock these menus. Unfortunately, my recent luck in the hobby has kept it's streak going. I can not upgrade with the card, the reader has been determined by Hector at Xicoy to likely be the culprit. I simply cannot use the card slot. So, I have to either send it back to my retailer (email has been sent), send it back to Spain, or leave it alone and just trust that it won't burn up the JP gear in my Flash Evo in it's stock mode. Any other suggestions from the brain trust?
Thanks in advance...
Tom M
Tom M
#300
My Feedback: (53)
I would sent it back....either to Spain or the store....
The risk is too great....you could burn one motor down and 2 up that refuse to go out or any other combination while in flight....if they don’t fail on the bench...First.
