Reload this Page >
Which Batteries you prefer for your jets
Old 04-05-2019, 10:06 AM
E.N.T.
Default Which Batteries you prefer for your jets
Just trying to obtain input from all of you and why:
  1. Li-po
  2. Li-ion
  3. Li-fe
  4. Li-Mg
  5. Others
Thanks for your info.
hmarmaizmd717
Old 04-05-2019, 10:36 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Li-Ion for RX and life for the ecu (because I have too)
Old 04-05-2019, 10:51 AM
BarracudaHockey
BarracudaHockey's Avatar
2S LiFe (real A123 actually) for the receivers
3S Life for the ECU
Old 04-05-2019, 10:57 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
4S2P 1100 mah size A123's for the rx, 3S LiFe required for the ECU with the KingTech's and they work fine for the JetCats.
Old 04-05-2019, 11:01 AM
Auburn02
Auburn02's Avatar
3S Life for the ECU
This all day. Can charge them in the plane, able to charge them and leave them without worrying about them puffing if you charge but don't fly, and they hold their charge forever.
Old 04-05-2019, 11:40 AM
camss69
My Feedback: (46)
camss69's Avatar
Same for me.
Old 04-05-2019, 11:42 AM
Len Todd
2 S LiPo for Rxers
3 S LiFe for ECUs
Old 04-05-2019, 12:06 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Real A123 (2 cel) for RX. LiFe (3 cel) for ecu. Bulletproof and charges in the jet.
Old 04-05-2019, 12:42 PM
aehaas
"Real A123 LiFe (2 cel) for RX. LiFe (3 cel) for ecu. Bulletproof and charges in the jet."
And same for me. You can leave LiFe batteries fully charged but LiPo batteries must be brought back to 3.8V/cell within 24 hours or they lose capacity over time. LiFe batteries do not blow up as a LiPo can. These must be charged outside the plane. Not a problem With LiFe batteries. Basically I will never use a LiPo again unless I Have To.
AEHaas
Old 04-05-2019, 12:47 PM
joeflyer
My Feedback: (48)
A123's for the Rx
2S Lipo for the ECU
Old 04-05-2019, 12:52 PM
wildnloose
Originally Posted by joeflyer
A123's for the Rx
2S Lipo for the ECU
Ditto.
Old 04-05-2019, 01:38 PM
sirrom
3S Life for the ECU__________________
Same for me
Old 04-05-2019, 01:39 PM
FenderBean
FenderBean's Avatar
Ions for RX and either LiFe or Lipo for ECU
Old 04-05-2019, 04:22 PM
rcflyguy_26
My Feedback: (8)
rcflyguy_26's Avatar
Old 04-05-2019, 05:44 PM
SECRET AGENT
My Feedback: (18)
SECRET AGENT's Avatar
Definitely LiFe A123 all around.
Old 04-05-2019, 09:43 PM
Dave Wilshere
In the U.K. most people use 2s Li-Po Rx and ECU. Powerbox is the main power supply and distributor and we are starting to see more people use the Powerbox batteries with built in chargers in larger models.
Old 04-05-2019, 10:29 PM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
I'm the black sheep i still use NiMh. 2x 6V 2000mah packs. Never had a failure
Old 04-06-2019, 08:05 AM
nil24
My Feedback: (12)
Specifically what brands are everyone using for the Life?
Old 04-06-2019, 08:38 AM
camss69
My Feedback: (46)
camss69's Avatar
I’m using the Kingtech Life for my ECU..
Fromeco for LiIon RX packs.
Old 04-06-2019, 09:41 AM
BarracudaHockey
Kingtech for the ECU
Receiver packs I get from WrongwayRC
Old 04-06-2019, 10:01 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Same here, KingTech has some big LiFe batteries for the ECU's and you can use those batteries for the JetCats unless you have an older ECU that has not been modified to accept the LiFe's. The good part about buying the other batteries from WrongWayRC is that those are all genuine A123 cells.
Old 04-06-2019, 10:03 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Originally Posted by rcflyguy_26
Man, I haven't seen one of those since I was a kid flying control line models.....
Old 04-06-2019, 01:12 PM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Electro Dynamics A123 for receivers/servos
Old 04-06-2019, 04:51 PM
JSF-TC
JSF-TC's Avatar
2x 5200mAh Jeti Li-Ions in both my jets. Both feed into the CB200/ CB400 for redundancy, plus a split off from one battery to also run the ECU. Starting the turbine is the limiting factor and I can get 4-5 flights before I need to charge. If I can start the engine, I have plenty of battery to fly.
They hold charge for months. Charge them as LiPo even though they are Li-Ion due to the charge protection.
Paul
Old 04-06-2019, 05:17 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
+1 on ED A123s
