Reload this Page >
New turbine X 45 ,by Gaspar
Old 06-06-2019, 07:05 AM
JP-1
A little history here regarding early model turbine development :-
Thank you to the Gas Turbine Builders Association
Alistair Powers
https://www.gtba.co.uk/history/
Old 06-06-2019, 10:12 AM
FenderBean
FenderBean's Avatar
Cool stuff
Old 06-06-2019, 12:01 PM
Gaspar
Gaspar's Avatar
Less than 45N, this particular engine gave 41N , below the test report. Year 1992. Propane fuel, a nice stainless steel gas tank on the plane. We have learnt one thing or two in 27 years!
Gaspar
Old 06-06-2019, 12:05 PM
Gaspar
Gaspar's Avatar
Oldest and newest...
Old 06-06-2019, 02:27 PM
jason
jason's Avatar
I received my X45 last Friday. I couldn't wait to fly it so instead of doing a lengthy install on it's intended model, I decided to put it in my small Wizard and it was in the air by Sunday. The Wizard is usually powered (over powered) by a Merlin 70. The X45 pushed it around very well indeed. First flight was 7 mins and over half the 2l tank remained. The second flight was 14 mins :-) The starts are very quick and it's a very smooth running engine.
Old 06-06-2019, 04:02 PM
  #31
ltc
Is that the ZNLine Wizard S?
https://www.znline.com/product/zn-sport%20and%20aerobatic%20jets%20fr/wizard%20s%20basic%20kit/french/1187970090/244/0/20/g0.html
If so, could I ask the dry or fully fueled weight of the plane with the X45?
Thanks!
Old 06-06-2019, 04:22 PM
  #32
jason
jason's Avatar
https://www.znline.com/product/zn-sp...4/0/20/g0.html
Thanks!
Yes, the Wizard Small.
Old 06-06-2019, 11:47 PM
  #33
David Gladwin
David Gladwin's Avatar
Default X45
Entirely endorse your comments re this engine, Jason. Exceptionally smooth and fast starts and propelled your mini Wizard (lovely airframe) with quite amazing speed.
Particularly like the integration of electronics etc in the engine itself, making it a really game changing engine.
Mine is on order for my Blanik sailplane, for which it should be perfect.
We are going to see a LOT of these engines !
Old 06-07-2019, 12:11 AM
  #34
philjac94
philjac94's Avatar
To be fair, Gaspar implemented this "Integration of Electronics" a few years ago, in the Jets Munt XBL series engines. What has changed, was it got smaller!
Old 06-07-2019, 04:15 AM
  #35
alasdair
alasdair's Avatar
Originally Posted by raydar
Alasdair if you want to see one in the flesh and a k30 give me a shout in a week or so.
I'll take you up on that.
And thank you to Itc for Henke's comparison chart. I'll save it this time, but hope for an updated version.
Old 06-07-2019, 05:53 AM
  #36
Gaspar
Gaspar's Avatar
Telemetry day!
This morning we have been taking videos of the compatibility between the X45 (or any other engine using a Xicoy ecu) with EIGHT different radio brands.
Powerbox Core:
FrSky:
Spektrum:
Multiplex:
JR DMSS:
JETI:
Graupner HoTT:
Futaba:
Gaspar
Old 06-07-2019, 07:05 AM
  #37
David Gladwin
Didnt realise that , Phil., my JetsMunt 100 has an external Xicoy ECU
Old 06-07-2019, 07:10 AM
  #38
FenderBean
FenderBean's Avatar
For your viewing pleasure!
Old 06-08-2019, 03:58 AM
  #39
jason
jason's Avatar
I've never seen a XBL engine without an external ECU, not saying they never made one it's just I have never seen one. The VT80 and VT90 have this though.
Old 06-08-2019, 04:11 AM
  #40
philjac94
philjac94's Avatar
The XBL series have almost a split ECU, where the engine carries run information and the external carries radio and pump information. The VT80/90BL has all incorporated in the Engine. The X45 at the moment is similar to the XBL where the pump is driven from the External Hub which is fed digitally from the engine ECU, it's possible later variant X45 will have the pump driven directly from the engine ECU similarly to the VT80/90.
Old 06-08-2019, 04:59 AM
  #41
sidgates
Gaspar,
I have a 2yr old M100XBL, do I need any thing else besides a Telemetry Adapter and the Lua script for Telemetry to work with my X9D with X8R receiver?
Old 06-08-2019, 11:12 AM
  #42
Gaspar
Gaspar's Avatar
Correct, you need a telemetry adapter version 5 and the LUA. downloaded from our website.
Gaspar
Old 06-08-2019, 12:36 PM
  #43
sidgates
Default Ordered
Gaspar
Thanks, downloaded the script and ordered from Jet Munts USA
Old 06-13-2019, 12:19 PM
  #44
RockiesGuy
RockiesGuy's Avatar
How is the production on the X45 looking for USA delivery? Before Kingtech fields theirs?
Old 06-13-2019, 06:01 PM
  #45
FenderBean
FenderBean's Avatar
I should be able to start feeling orders for the pre-orders in about 2-3 weeks!
Old 06-14-2019, 01:26 PM
  #46
FenderBean
FenderBean's Avatar
I will be setting my price to honor Xicoy’s release cost of 1500€ I’m having is some confusion, people see 1500 and forget this is Euro the USD conversion depending on the daily rate is $1700 to $1730ish plus tax and shipping.
I hope this will help clear up some confusion.
Cheers!
Old 06-15-2019, 05:20 AM
  #47
raptor30se
I received first one in US week before last but have been traveling and haven’t had time to start yet. I did open and began mounting to test stand and plan on starting tomorrow. Really like the size and craftsmanship. I’ve flown Jets Munts for awhile and knew quality would be top notch and no disappointment there. I know people like the “other brand” but analogy would be Chevy vs Cadillac in terms of construction and electronics this one offers.
Old 06-15-2019, 10:14 AM
  #48
ltc
Just noticed the right angle fuel connection.
Is the 3 pin electrical connector right angle?
Curious how far out from the motor diameter the connector/cable sits compared to the fuel line.
Old 06-15-2019, 12:32 PM
  #49
Gaspar
Gaspar's Avatar
Currently not, but soon we will offer an small board with a right angle connector so that the cables will exit to the front. In same board there is an extra connector for the fuel pump, allowing the pump to be connected directly to the engine in installations where the pump should be close to the engine.
Gaspar
Old 06-15-2019, 07:35 PM
  #50
ltc
Gaspar
Thank you
That sounds great.
