Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 07-03-2020, 09:35 AM
  #151
Agrav8ed
Thanks everyone for the input. It is appreciated.
Tone
Old 07-03-2020, 10:00 AM
  #152
skymaster68
Tone
I edited my post... I used 1'' servo arms all around and 1.5'' on rudder.....
bodywerks (07-03-2020)
Old 07-04-2020, 01:41 AM
  #153
jamessymons
I have a few questions since this is my first Rebel.
1. The clevis they use appears to have a 3mm clevis pin. I was under the impression that aluminum pin on an aluminum would build up slop. Is everyone using this clevis's or are they upgrading to ball links?
2. What length servo arms are being used on the elevators?
3. Does this jet tend to require nose weight? I noticed from the pics that many pilots are placing the batteries right in the nose.
4. Besides fuel proofing the wood, are there any other tips or tricks I should keep an eye out for?
5. I could not find the threaded link for the elevators. Is this an oversight or something we are supposed to provide?
Tone
5. Threaded rods should be in bag marked "Stab". That's where mine were.
Old 07-04-2020, 04:37 AM
  #154
Agrav8ed
Yes, the Stab bag had no threaded rods at all. The wing bag had 4 rods, but two of the are really bent. I'm sure it was an oversight. Think I will reach out to Carf for replacements. Otherwise, the kit looks great. And is really super light. It amazing how light it is.
Tone.
Old 07-04-2020, 05:43 AM
  #155
Dansy
My Feedback: (53)
Dansy's Avatar
I never used those...I rather used either SWB 4-40 titanium or the Secraft 3mm stainless steel.....both available in the USA...
Old 07-04-2020, 06:16 AM
  #156
bodywerks
bodywerks's Avatar
Tone.
You'll spend forever and a day trying to get 15 cent replacement hardware. Just get turnbuckles or order 3mm threaded rod on Amazon.
Old 07-05-2020, 01:46 AM
  #157
jamessymons
Hi Tone
From the work that I have done on mine, I noticed the following
1. The servo mount openings in the stab are not exactly in the same position.
2. The slots cut in the stabs for the servo horn exits are too small as well as not being in the exact same position. So you will have to make them bigger.
3. On the rudder servo mount you will have to relieve some of the wood on the mount as the rudder servo cavity tapers and once you glue the plywood mount in the hatch will not fit.
Hope this helps.
Kind Regards
Jame
Old 07-05-2020, 05:16 PM
  #158
Agrav8ed
Hi Tone
Hope this helps.
Kind Regards
Jame
Thank you for the in sir! It gives me something to look out for. I really like the lines of this jet. After building the SAB Drake I really liked the large radio tray so I decided to use some faux carbon fiber and add one to the Rebel also. I did leave a cut out though so that the fuel tank can be visualized.
Tone
ID:	2267772   Click image for larger version
ID:	2267773   Click image for larger version
Old 07-05-2020, 10:30 PM
  #159
jamessymons
Mmmm. That gives me an idea. Thanks Tone. She is a looker indeed. Some pics for you.
Old 07-24-2020, 01:57 AM
  #160
jamessymons
Was looking yesterday at the fir of the JP retracts as supplied and assembled by CARF with the kit. I think they have the struts on the wrong way with the wheel facing outwards. With this setup the wheels stand proud of the wheel well. Will have to change them around i think. Also looks like the flap servo install is going to be some fun ... not !
Old 07-24-2020, 03:29 AM
  #161
bodywerks
bodywerks's Avatar
LOL. Uh, yeah, they assembled them wrong. As received from CARF:
paulhat (07-24-2020)
Old 07-24-2020, 11:56 PM
  #162
jamessymons
Thanks Bodyweks !
Old 07-25-2020, 09:29 AM
  #163
Dave Wilshere
Finished setting up club member Steve Hartley’s Rebel and test running the new JetCat P-130Rx ready for a test flying day soon!
His first turbine we did several runs while I coached him on operating a turbine. Four perfect runs.
The following 2 users liked this post by Dave Wilshere:
DenisFerrari (12-21-2021), Desertlakesflying (07-26-2020)
Old 07-25-2020, 08:02 PM
  #164
bodywerks
bodywerks's Avatar
No smoke and simple set-up. I'm guessing 10.2kg? That thing will be a lightweight ROCKET with that underrated 130!
Old 07-25-2020, 08:59 PM
  #165
Dave Wilshere
Didn’t weigh it, it’s as light as it possibly could be, nothing extra added anywhere. Yes, I was explaining to Steve he wouldn’t need full power for the majority of the flight.
Old 08-01-2020, 07:17 PM
  #166
Agrav8ed
I thing I got my layout set up okay. I had a bit of a problem with my Electron retracts and had to send them in for service. One they are back I can mount the batteries and perform a final balancing.
Tone
ID:	2267942   Click image for larger version
ID:	2267943   Click image for larger version
Old 08-01-2020, 07:28 PM
  #167
bodywerks
bodywerks's Avatar
You're leaving your GSU installed on the jet??? Other than changing parameters the GSU completely unnecessary. The swiwin has telemetry built in and shows you everything you need to know during start-up.
Old 08-02-2020, 07:51 AM
  #168
Agrav8ed
I normally do on the larger jets that have room for it. That way if I need to adjust a parameter or test a starter, do manual cooling or something its already there. Guess I have just become used to it. And since every turbine comes with one there is not point in having them just sitting around. Also makes a great display screen in the cockpit of my Harlock.
Tone
Old 08-03-2020, 04:22 AM
  #169
Scott Baker
How does the 2m Rebel compare to the Ultra Flash speed wise? Ive got a Jetcat 140rxi for power..
Old 08-03-2020, 08:01 PM
  #170
bodywerks
bodywerks's Avatar
With a 140 it will definitely not be anywhere near as fast as the UF. If you really push it with a 140 I'm sure you will approach the 200mph mark, though. It is no slouch with a 140. Built right(light), it should be around 23lbs and will have around 1:1 thrust at take off. My buddy has one flying(and mine is on the bench being built) with a 140 and it cruises at 160ish at 3/4 throttle all day long. Like I said, push it a little and it will get near 200 for sure, but be careful - it's not meant to be a speed demon and has ZERO carbon fiber reinforcement in the fuse. I'm building mine with a 170N turbine, but I know how to use my left stick and will be extremely careful about over-speeding the jet. I want the thrust for accelerated vertical.
The UF Evo with a 140, built right(light) will be 21.5lbs and will have greater than 1:1 thrust at take off, and 200mph in it's sleep. It is a sleek airframe and plenty aerobatic, but the Rebel is a slightly better jet for sport/precision aerobatics, from my experience. Even though my Classic isn't flying yet, I have many flights on my over-powered Rebel HOT(powered by an 85N turbine with a 16.5lb take-off weight, full of fuel - 13.25lbs dry), and just maidened my moderately over-powered Rebel Pro(36.75lbs dry powered by a Swiwin 220N turbine). And I have a half-dozen flights on my UF Evo with a 140N turbine.
Bottome line, if you are more into speed, get the UF. If you want decent speed and great aerobatic capability, get the Rebel.
Old 08-04-2020, 09:03 AM
  #171
Desertlakesflying
My Feedback: (28)
I can fly my 2M Rebel up here at 5000' at about 1/4 throttle very comfortably with the 140. It's wayyyy too fast with full throttle, and have only done that a couple times.
bodywerks (08-05-2020)
Old 08-04-2020, 09:48 AM
  #172
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
140 would be adequate. I have a Cheetah 160 in mine and I'm always slowing it down. Anything above 1/4 throttle at level flight - it is consistently gaining speed incrementally. If I were to do it again, I would use a 100 or 140 max.
bodywerks (08-04-2020)
Old 08-04-2020, 01:04 PM
  #173
bodywerks
bodywerks's Avatar
Adequate probably not the best word to describe it. Perfect, is the better word. If I had another 140 lying around it'd go in it. But I like coming across the runway, slow with full flaps, near stall, then advance throttle, flaps up, pull vertical, and accelerate! My Rebel HOT does it perfectly with an 85n turbine, and I'm sure my Rebel classic, at 24lbs dry with a 170, will do it even better!
Old 08-05-2020, 05:04 AM
  #174
Desert Fox 1
Cheers!
Desert Fox 1
Old 08-05-2020, 10:18 AM
  #175
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Originally Posted by Desert Fox 1
https://youtu.be/UTWsbdQmFEY
Cheers!
Desert Fox 1
Nice flight! If you do not mind me asking, are you using any expo on the Ail or Ele? If so, what %?
