Cortex Standard gyro >
Old 01-10-2020 | 05:50 AM
My Feedback: (15)
Default Cortex Standard gyro
First time user of this brand. Manual says it can be configured with sum signal? I assume a Spektrum SRXL connection should work. This would get fid of the piggy back jumpers and the servos can be plugged into Cortex? Are the remaining slots on Cortex usable for other channels/ servos? Any input is appreciated. Thanks
WHMC is offline
Old 01-10-2020 | 07:56 AM
ravill's Avatar
Um...what?
ravill is offline
Old 01-10-2020 | 01:43 PM
My Feedback: (57)
I believe the Standard will only take Serial (SBUS, etc.) in, with PWM out (must use the wire loom). The Pro on the other hand will do SBUS in & SBUS out.
George is offline
Old 01-11-2020 | 02:46 AM
Bob_B's Avatar
Srxl is not compatible with Either Cortex. You will have to use the wire loom.
Bob_B is offline
