Fuel Pump
- Have the fuel filter loose, not hard mounted
- Have the fuel filter vertical, not horizontal
- Mount the fuel pump horizontal
- Move the manual fuel shutoff to the pump input line
- Wire lock the fuel lines on the fuel pump
Paul
My Feedback: (53)
I see 5 things. Not sure the same 5 as yours though.
Paul
Paul
1- yes
2-not required
3-either way work......but I don’t like the bend in those fuel, line seem flat...might be the photo.
4-perfect were its
5-yes
Did this just to show..there’s more then one way, the proof is in the running......motor will either run or be only trouble.....
My Feedback: (54)
You forgot, do not use Festo’s on the suction side.
In one of my jets, I do have my pump mounted vertical. I mounted it this way for convenience and nothing to do with the system. Guys, other then that engine position for start, none of the other stuff should matter, other than maybe the BVM UAT, and that is truly only for filling to help keep the air out. Think about it? When flying, are you always flying level? Or do you go vertical, inverted, dives, etc.
My Feedback: (53)
A perfect cut is required (I’m using Festo cutting tool(pliers))...and if you undo that connection a lot....a clean cut once in a while will prevent leak...
I only used Festo fitting in all my jets....for the last 5 years.....never had a flame out....(touching wood LOL)
