Jettronics dual action valve setup
My Feedback: (7)
Seems surprising to me but I can't find anything anywhere online to answer my Jettronic valve question:
I'm operating a system with one (dual action) valve for gear and one for doors. Here's the problem: if I hook them up to a common pressure line (ie. one tank) the door valve will cycle fine but the gear valve just blows air out the vent!! It won't cycle the gear. If I run separate tanks it all works fine. No, I don't have any leaking I can find - the system holds air forever.
I do NOT want to have to run three air tanks (one for brakes too). What the heck is going on?
My Feedback: (7)
To all those that said (in various threads) CHECK YOUR SYSTEM FOR LEAKS - I say SPOT ON!!
And thanks finally to Vincent. I finally clamped off each gear in turn and found massive blow-by in the right gear. So I pulled the wing and CANNOT get it to blow-by on the bench. But it most certainly is. When clamped the gear work flawless and when up if I unclamp the right gear (Up line) air immediately dumps out of the up solenoid (only source is now the right DOWN line - through the cylinder).
Cant imagine why it won’t leak on the bench but a cylinder rebuild is in order.
Let this be a lesson to all the other hard-headed folks out there. I would’ve bet the farm my system was just fine.
I have a similar problem with my Jettronic dual valve, but I can't get air to come out of the second #2 cylinder port. Only one works. I am not even sure how to plumb it because the instructions are really inadequate. I assume one of the #2 cylinder ports are gear/door up, and the other #2 cylinder port goes to the same cylinder, but down. Is this correct? Thanks for any suggestions.
