EMBRAER145 jet 4,7m length build
Hello from Greece!
I'm Fotis and i will present to you the constraction of the handmade EMBRAER 145 JET with a length of 4.7m.
The constraction materials are:
Foam
balsa 2mm
plywood
fiberglass 80gr for the wings
fiberglass 50gr for the fuzelage
carbon 125gr.
I apologize for my bad English but i will try to tell you as many details as possible.
Enjoy it!!!
Foam
balsa 2mm
plywood
carbon 125gr.
Enjoy it!!!
cptnassos (09-07-2020)
bodywerks (09-04-2020)
Thanks!I
will have it ...
static though. will be removed during the flight.
aerodynamics change a lot. maybe after many flights and tests I can leave her standing up.
will have it ...
Smokeyr67 (09-06-2020)
Well done fotis keep going. Nice progect.
fotis kalevras (09-07-2020)
Impressive, looking good.
Regards,
Regards,
fotis kalevras (11-18-2020)
