Use of diesell
Calling that the “standard” is a bit of a stretch; Kingtech, Jetcat, and Swiwin in their most recent manuals suggest 5% oil with all fuels to include diesel. But I don’t manufacture or service turbines so I can’t tell you why that is.
Preparation of Fuel
In a clean fuel container mix fuel using the following ratio:
3% oil diesel
5% oil Kerosene or JetA
General rule of thumb is to mix 5 gallons of fuel.
For smaller or larger amounts the following formula can be used:
Gallons fuel X 128 X .03 or .05 = ounces of oil
If that has changed then I apologize for the misinformation. I only run Kero.
Tone
My Feedback: (7)
We fly mostly Kingtech's who request using diesel for all but their tiny engines. Most jet pilots use the 5 gallon containers so here's an easy way for us to remember. For Jet A, we put in one quart per 4.75 gallons and for Diesel, we put in one quart per 5 gallons (yes, those tanks will take all of it even if over 5 gallons) Hope this helps.
John
John
My Feedback: (13)
Not sure why, but JetCentral recommend much less when using 2 stroke synthetic oil for the SE series:
Jet Central recommends using 2 stroke 100% synthetic oil mixed in 1.5% (66-1) to 2% (50-1) ratios. Any recognized brand that meets the norm “JASO FC” will work. Another alternative is 100% synthetic turbine oil mixed in ratios from 2.5% (40-1) to 5% (20-1); however this type of oil is not recommended from a health and safety aspect because it’s been proven to be toxic. The last alternative is Mobil DTE light with a mixing ratio of 5% (20-1).
This one? What do you like about it? and how's it different from KT oil or aviation oil?
https://www.amsoil.com/p/dominator-s...acing-oil-tdr/
My Feedback: (13)
My Feedback: (28)
I get a gallon for about $40. (I buy it by the case of 4 1 gal jugs) I use 12.8 oz per 5 gal of diesel. That comes out to 10 batches of fuel per gallon of oil or about $4 per batch. As said in another post it dyes the fuel red which makes it easy to see in your tanks. I have never had a bearing issue since i started using it. Ive used it in my KT also. Im not paying $45/gal for DTE lite
