Wing tube help >
Wing tube help
Wing tube help
Old 06-11-2022 | 12:39 PM
Default Wing tube help
I need to know the wing tube diameters and lengths for a couple of jets, and where would be the best place to buy some new ones.
Wild Hornet
Kangaroo
Boomerang Elan
Also is there a partial second tube behind the main tube on the boomerang Elan?
Old 06-11-2022 | 02:53 PM
Years ago, I contacted Ray LaBonte (sp), who is a CARF dealer, and bought a nice thick walled replacement wing tube for my Kangaroo from him.
Hope that helps.
Greg
Old 06-11-2022 | 04:07 PM
Zeeb's Avatar
My Feedback: (41)
Hmmm....
Every time I've bought a different wing tube, the manufacturers' go by dimensions only. Never found a vendor who had the specific model information you seek? That information usually has to be gotten from the model manufacturer.
Old 06-11-2022 | 07:04 PM
CARS II's Avatar
My Feedback: (7)
Same here for Roo and B XL rear tube.
Old 06-11-2022 | 09:52 PM
Default Wing tubes
Hi don’t know these guys can help but I have used them
https://www.fighteraces.co.uk/shop/a.../1m-wing-tube/
Old 06-12-2022 | 08:18 AM
My Feedback: (26)
Can't help with the Hornet or Roo, but you can try contacting Boomerang Jets ( https://www.boomerangrcjets.com ) for the Elan. If he doesn't have the tubes he should be able to point you in the right direction.
Old 06-12-2022 | 03:00 PM
sc0tt's Avatar
My Feedback: (61)
Hey Joe - for Kangaroo see manual page 30 - aluminum wing tube is 16 x 2 x 820 mm
https://carf-models.com/files/page/8...structions.pdf
old Elan manual if you need it - page 8 - only dimensions are for the aluminum dowels fwd & aft of wing tube
https://cdn.shopify.com/s/files/1/02...f?v=1619905411
Old 06-12-2022 | 03:04 PM
mongo's Avatar
My Feedback: (15)
are the original sockets, carrier bushings not in the wings/fuse?
they will give you the od dimension you need, and the lengths can be measured and added to get a total for each. that just leaves having to decide on a wall thickness dimension.
Old 06-12-2022 | 03:53 PM
CARS II's Avatar
My Feedback: (7)
I got both spars, I want a CF spar for the Roo and will need the Boomerang XL rear spar for another project.
Need measurements,? I got.
Old 06-14-2022 | 12:38 PM
Thanks everyone for your input.
