Jeti Diference between R11 REX12
This REX line of Rec, especially the REX 12 has these small end pieces just before the end of the Antenna .
https://www.jetimodel.com/katalog/du...x-12-epc-1.htm
What is the benefit from this compared to the standard short antenna on must RE receives?
The discussion is that the REX 12 with the end pieces helps maintain a stronger signal and using of a REX3 as secondary Rec with the same extended antenna and blubs on the antenna ends helps maintain a strong signal !
Viper1GJ (07-20-2022)
