Older Jet Central Rhino problem
I have a older Rhino at least 15 years old,I started it today
for the first time this season.It started fine on the propane and switched over to fuel also. I brought the trim down too low and it caused a flame out.,it said that on the display.
Now it won't restart at all, Do I need to due something to the ecu to get it to restart?
Jerry B
Jerry B
![](/forum/images/badges/premium_member.png)
My Feedback: (26)
Couple of thoughts, I've run into the not idling issue before when the engine has sat for a while, for me it cleared up after a bit of running. I think what happens is the old oil gums up and there is more drag on the bearings until they get hot and new oil through the bearings. With regard to the not restarting, did you check your glow plug, you didn't say if the engine would light on propane or not.
