CARF Diablo build thread
#76
I've got about 15 flights on mine now and settled on a nice CG. Total weight is 12.7kg (28lbs) with fuel in the UAT. All batteries are next to the nose wheel, and I have ~200g in the nose of the canopy. SW220 for power and MAP 6oz UAT, PB pioneer. I have 9.1% of the weight on the nose wheel (nose wheel weight ÷ by total weight). I'm not sure where this lands on the wing, but checking wheel weight % is easier to do solo. I've experimented with going as far back as ~7.5% nose weight and it was extremely pitchy. This feels like a nice balance to do both sport flying and 3D.
#78
thx
#79
Battery size and equipment placement covers everything, if you are using one of the 220 size turbines it’s going to be similar to my pictures.
My guess is he is flying nose heavy because it suits him, without doing the simple balance check with a string we don’t know exactly where his weight on the nose wheel figure puts him.
#81
My Feedback: (46)
Another was just finished here with a Behotec 220, also balanced perfectly without any weight.
#83
With the canopy on, gear down, hopper full and just the ‘sump’ full of fuel at the back of the main tank, 400mm back from the leading edge joint. I’ve played between 400 and 405mm in the same state. Expo with 42mm up and down elevator is around 65%.
I tie a knot on the string and trap under the wing/fuselage joint.
FlyJ Carbon frame would add weight and full Powerbox. So you have not saved weight with minimum equipment, everything would need mounting forward.
I looked at my balance/weight at the beginning and I had about 1070g on the nose wheel.
#85
Without knowing your total weight, 1070g doesn't give us much information.
Nope, it's a felt clunk. The photo is just after defueling. You can see the nipples are about even with the fuel.
camss69 (05-13-2024)
#87
Dave you may have posted it before but what’s your balance with a string look like completely pictured? What do you have the strings attached to. Also what is on the other side of the wing, I think before you posted a picture of just knots but I’m not sure I’ve ever seen the whole setup. Thanks.
Answering properly, I tie knots on each end (knots on knots to increase the physical size) trap the cable by the wing with the knots under the ideal balance point. It’s one loop of string and with the model on the ground I pick it up.
camss69 (03-19-2024)
#90
Just finished up David’s (LA Jets) build.
13.1kg with UAT full and empty tank.
CG 395mm
MKS HBL599/HBL599SL/HV1220
Jeti REX R12/REX R7 A40/R3 RSW/SBEC 30
bavarianDEMON Cortex Pro
Elite GPS
Xicoy X195
Fun build. Typically nice CARF quality
CG 395mm
Elite GPS
Xicoy X195
The following 6 users liked this post by F1 Rocket:
AEROSHELDON (01-28-2024),
Canadian Man (01-29-2024),
Ken Bryant (02-03-2024),
LA jetguy (01-28-2024),
LimitDwn (01-29-2024),
and 1 others liked this post.
#91
Skunkwrks (02-23-2024)
#92
Test flight today of the first non vector Diablo, powered by a JetCat P-130Rx-B. Four perfect flights, had owner Lewis smiling.
Futaba guidance, with Powerbox Mercury SR-2, i-Sat Gyro and MacGregor servos.
Lewis’s visit meant three Diablo’s at our field, probably the first time in the World three have been together on one airfield.
#93
Another Diablo test flown this weekend. Non vector, JetCat P-160Rxi-B MacGregor servos, Powerbox Core. Covered in Uni lights 🙄
Heavy for a non vector at 13.2kg with all the extra equipment and ‘bling’
Still flies great.
Still flies great.
#97
Would 250 XBL be too much for this , as I happen to have one laying around..
And is the little wing removable, I dont like the looks of it , spoils nice lines sitting on top of the canopy..?
#100
My Feedback: (46)
Getting ready to start my build, plane came in last week and looks amazing and insanely light.
On the fuel tank mounts, I’m going with the KT210, mounts should go in front of the wing tube correct? Do I want it up against the wing tube or slightly in front?
On the thrust vector pushrods, are they the correct length as received? Do I just use JB weld or epoxy to secure the threaded part into the carbon tubes?
I also usually replace the other pushrods with turnbuckles but this time I’m going to try to use the included hardware. The carbon that slides over the all thread, do you glue it or is it just free floating over the threaded rods?
Is there still no manual? Most things are straight forward but there’s still some questions.
Thanks!
Thanks!
