Is this a jetcat turbine?
![](/forum/images/badges/premium_member.png)
Hello, I purchased this turbine a few years ago to put in my Tamjet A4 and I am trying to get info on it because I wont be using it in my A4.. Going EDF.... Can someone give me some info on it? Thank you for your time.
![](https://cimg1.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1440x1800/e214656c_3cdb_45ce_8f2b_ac107a568779_d43fa3b8aa1cf03636218af6b6bcacdc91991052.jpg)
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1440x1800/e783fb2e_2f44_4e81_a14c_49d259b19314_080a05dbab971a699edc66eb218d662c72d9e4b1.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_5494_f645654947e44b9ffcf01329364a5279183c2519.jpg)
![](https://cimg6.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_5495_b52acae7bb4965d3f62b4e3286769b999b0e5e6e.jpg)
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_5496_f1145401dbe143dfedc91bd4474a02b6ff1d5d95.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_5497_92b21d06b8cf5d19d6a628f3980975cca6dc86a3.jpg)
It’s an old jetcat maybe a P80 or P90 with a kerosene start adapter.
You need to power it up to see exactly what it is and how many hours are on the motor using the GSU (The black box)
It’s a P-70. Reduced diameter P-80 done primarily for Bob Violet so it would fit in his converted EDF models. The reduced diameter lost some power, so actually around 16/17lb thrust when first released.
Cool! Thank you Dave! One question.. I wanted to test the engine on a test stand and seen some guys have a really nice set up to do so, What would you recommend besides clamping to a bench? lol Thank you for the help!
Turbines are not fussy, you can bolt it to a wooden pallet, almost no vibration, the force is all shear through the mounting screws.
if you use a work mate type tool bench allow for the turning moment, so have the front against a wall or back weighted down.
shredder777 (10-18-2023)
Rad! Thank you sir! I will do that... I will get 3/4 plywood for all the accessories to mount it to. I will make it happen.. Appreciate the help!
