JMB XXL PC-21 landing gear
I fly with Dennis Shrewsbury fairly often. We were together a couple weeks ago and he put several flights on his. The nose gear gave him some issues. The lower strut threads into the upper housing with a very fine thread. This thread was so fine and the tolerances not too good that it allowed the strut to just fall out. Luckily it fell out while rolling it back into the pits and was not lost. He added a couple of set screws to hold everything together. Seemed to do the job.
GBarnes, thank you for your response, much appreciated.
would be great if you could get Shrewsberry to weigh in here. Would love to see a picture where he put set screws.
would also appreciate what throws he ended up with on ailerons, elevators, rudder and flaps as manual has no recommendations
thanks
Roy
Minnesota
thanks
Roy
Minnesota
Roy, I don't think Dennis is on any forums or social media. Just not his thing. Most of his setup came from Ebel. We are scheduled to get together and fly the first weekend in December and I'll see if I can get you a picture or two.
Thanks that would be very helpful. Would be great if you could eyeball control throws. Can’t believe the kit has been out for a few years and no mention of control throws anywhere including the manual. I had PM into Ebel but never got a response. I wonder if others had issue with nose gear.
Roy
Minnesota
Roy
Minnesota
Roy
Minnesota
Roy
Minnesota
I have about ninety or so flights on my pc21. The threads on my nose came loose after 60 or so flights. Never really had an issue except that my steering got a little clumsy. Took it out - put some thread locker and I was good to go.
Other than that it has been flawless.
Guldukat, thanks for response. Maybe I will be proactive and thread lock nose gear. Since you have yours dialed in I would be grateful if you were to post your control throws and flap settings
All my turn buckles are on the outside. And I have maxed out all the throws.
