Essential gear for a new Turbine owner?
My Feedback: (10)
I ordered a BVM Bandit Evo. I have been talking with the guys at the field and looking at their equipment. So far I have a short list of items I need to get for ground equipment.
BC fire extinguisher
Jersey Modeler fuel container/pump.
Some sort of blower to cool the turbine.
Over flow fuel catcher.
wing, tail and Fuselage bags..not needed but nice to have
Stand to assemble and work on at the field.
Any other suggested items?
Wayne
Ken Bryant (12-03-2023)
You say "BC" fire extinguisher, that could encompass several kinds including dry chemical.
You want CO2 or Halotron
You also want water based fire fighting, usually a pressurized water extinguisher in case you catch grass on fire, our clubs have them but that's part of the requirement
Great thread. Regarding the blower, I don't think you need it at all. All modern turbine cool off automatically even with the receiver turned off. The fire extinguisher you need is CO2. No need to get a huge one.
A few more jet specific things I use or carry all the time:
- fuel containers I use to purchase JetA at the local airport. You want to mix in these containers and then refill your jersey
- turbine oil as recommended by your turbine manufacturer. I personally use Kintech's oil because it works in Kingtech, Jetcat and Xicoy
- water fire extinguisher, especially when flying during summer. Get a large one. This is the best way to immediately control a grass fire
- safety wires and safety wire pliers. This is for your fuel lines. Your fuel system needs to be absolutely perfect or flame out will take place and these quickly lead to a bad day at the field.
- rechargeable air pump with quick disconnect. I prefer to use the robart air line quick disconnect but several are available.
Hope this helps. Great choice on the bandit. It is a really fun airplane. Welcome to turbines!
The following 2 users liked this post by acw:
Auburn02 (12-04-2023),
My Feedback: (10)
Halotron is pretty much what I was looking at. Water is at the field
One thing…
Add decent hearing protection to the list. You must test the turbine properly for any air bubbles etc. repeatedly. Its much nicer to work the model with hearing protection. Or if another modeler needs help with their model.
TP.
TP.
uncleTom (12-03-2023)
If you ever go to fun flies you will need your own water based fire extinguisher. AMA "rules" require both a BC and water based extinguisher at the field.The host club may or may not have it available. I have been to a number of fun flies that the host club did not have water based available.
Another item is an exhaust deflector to save the grass if you are at a field that does not have it.
I just moved into the turbines this year and I'm still learning also. I just heard about the funnels that remove the water from your fuel will you fill up at the pump. I'm going to get one it seems like a good idea.
My Feedback: (7)
Mr:Funnel or one like it from ACE hardware for a lot less.
https://www.acehardware.com/departme...E&gclsrc=aw.ds
Tone
Don't forget some basic tools. Screw driver, pliers, hex wrench. Add some connector safety clips, tape and wire ties.
CO2 Fire extinguisher and as for the blower, I recommend a batter powered fan with some aluminum ducting attached so you can sit it as the rear turkey feathers and pull the heat. A blower doesnt work all that well because the hot section is in the rear as well as the temp sensor. So pulling the hot air out the rear is much more affective, because the compressor inlet is rather small and doesnt flow there the only air thats going through the motor is what the compressor is pulling wit the starter is spinning for cool down.
Boomerang1 (12-07-2023)
