Powermax Triggers
OH
Would any of you guys be interested in a Powermax Valve that I designed and built for $12.00 plus shipping? It will fit all the Butane canisters too ie; Coleman Peak, MSR, and Campingaz.
Todd
Todd
OH
Ok - here's a picture of it. Currently resizing 2 more photos to post here. Will load them in tonight, if all goes well. The valve is for Powermax and will fit MSR, Coleman Peak, and Campingaz. $12.00 plus shipping and handling. To release gas, turn valve clockwise. To shut off gas turn counterclockwise. Compared to the Trigger Gun, you can have a constant gas supply if desired. All valves are pressure tested before being shipped out.
The valves can be ordered in 3mm or 4mm configurations. I have over 900 valves on the shelf. All that is needed is for me to do some machining, get the fittings, assemble, test and then they are ready to ship out. Couldn't see spending a lot of time getting everything together and assembling them unless there is a demand. Can fill whatever type of orders you folks are looking at. Can't do credit cards at the moment as I've just gotten up and running with my business. Can do Postal or Bank Money orders. If interested in ordering the valve or valves, e-mail me at:
[email protected]
Will try and get the other 2 pictures in after posting this. Thanks!
Todd Walters
[email protected]
Todd Walters
OH
Picture #3
I also designed and built a Turbine Test Bench that is fully adjustable with a thrust scale. Can handle any size turbine from smaller than the Simjet 700/Wren-44 up to 35 lbs. thrust. All aluminum construction with carry handle. $190.00 plus shipping - currently have 8 kits in stock. If interested, I can post a new thread with pictures.
OH
These come almost completely assembled. Assembly only takes about 10 minutes. Comes with Velcro to strap your ECU, Rx, battery packs, etc. Velcro colors of you choice: Black, Green, Red, Yellow, or Blue. You don't have to attach Velcro - some folks like to drill and tap there components into place. All aluminum construction and is 12"W x 24"L. Unit is fully adjustable to fit any size turbine up to 35lbs thrust. Has a carry handle for convienance and comes with a thrust scale.
