Flying Fast >
Flying Fast
Flying Fast
Old 05-05-2002 | 01:11 AM
Default Flying Fast
HELLO JET GUYS! I AM IN THE PROCESS OF BUILDING A STARFIRE JET. I KNOW THIS MODEL WILL FLY OVER 150 MPH AND I WOULD LIKE TO BUILD A PROP MODEL THAT WILL BE CLOSE TO THIS SPEED RANGE TO GET A FEEL FOR THE FASTER MODELS. CAN ANYONE RECOMMEND A PROP PLANE / ENGINE CONFIGURATION THAT WILL FLY VERY FAST. THERE IS ALSO THIS GUY AT THE FLYING FIELD WHO IS CURRENTLY FASTER THE REST OF US AND I WOULD LOVE TO TO KICK HIS ***. THANKS GUYS!
Old 05-05-2002 | 02:20 AM
JohnVH's Avatar
My Feedback: (38)
Default Flying Fast
get a diamond dust, doesnt look like much, but they are FAST
or a weston magnum, there supposed to do 200!
Old 05-05-2002 | 02:48 AM
AirRayInc's Avatar
My Feedback: (7)
Default Flying Fast
David,
Think Shrike
http://www.lanierrc.com/lrcprivate/L...s/shrikes.html
Ray
Old 05-05-2002 | 03:41 AM
Default Flying Fast
HEY JOHN WHERE CAN I PURCHASE A DIAMOND DUST OR WESTON MAGNUM. 200 MPH SOUNDS GOOD.
THANKS
DAVID C.
Old 05-05-2002 | 03:45 AM
JohnVH's Avatar
My Feedback: (38)
Default Flying Fast
Do a search on it, I cant remember where I seen it.(magnum)
www.diamonddustrc.com
Old 05-05-2002 | 04:04 AM
Default Flying Fast
THANKS GUYS FOR THE INFO.
KEEP BURNING THE SKY!
DAVID C.
Old 05-05-2002 | 11:44 AM
Default Flying Fast
Look for the Magnum here. JD Enterprises.
http://www.jdenterprise.net/latest_update.htm
Old 05-05-2002 | 11:51 AM
Forgues Research's Avatar
My Feedback: (7)
Default Flying Fast
I think your best bet would be to go for the fully composite ARF Whiplash from ACM
http://www.geocities.com/roger_forgues/Whiplash.html
Check it out.
It is now becoming the standad in high speed trainer for jet jockeys
Old 05-08-2002 | 04:16 AM
Default FLYING FAST (CLOSE THREAD, FOUND)
I REALLY APPRECIATE THE INFO ON THE FAST AIRCRAFT GUYS. THE MAGNUM AND WHIPLASH ARE VERY GOOD CHOICES. I CAN'T WAIT TO GET ONE AND GET STARTED!
THANKS AGAIN!!!!!!
DAVID200MPH
DAVID C.
Old 05-08-2002 | 05:00 AM
Default Flying Fast
//// MODERATOR /// Please close thread, I have found the aircraft I have been looking for.
Thanks!!!!
Old 05-20-2002 | 04:35 PM
Miguel Santana's Avatar
Default Flying Fast
David,
I STRONGLY recommends you the Kangi, which is the F3D from Super Kraft ( www.kangkeeusa.com), the cost is very low, just US$158.00.
I builded one, is all fiber composite.
I putted a OS. 46.VRF Ducted Fan ( purple head). It turns a 7.4 x 8.5 carbon fiber APC at 25K RPM!
The kit call for a .30, so some modifications have to be made, basically removing the actual fire wall and installing a new an stronger one. I cutted the fuselage a couple of inches to not affect the CG.
The plane flies at almost 200MPH. It beated a Hot Spot with a Ram 500.
The wing need reinforcement only at the tips, because is laminated.
Regards,
Miguel.
Old 05-20-2002 | 06:31 PM
Default diamond dust
Best place to get the diamond dust is morris hobbies. I put a jett fire 50 on mine. My second dust is being built now and has a jett fire 60.It s outfitted with an autopilot feature. Ill let you know how that works out.
