 microjet esc... >
microjet esc...
microjet esc...
Old 11-07-2003 | 12:15 AM
Default microjet esc...
Hi I'm thinking of getting a microjet or twinjet, I'm leaning towards a microjet. Was wondering which esc would be good for the stock motor on 8cell KAN 1050s...???or should i use Sanyo 1100 AEL Batteries??? since these are Nicd and the KAN are Nimh... which esc, please let me know... (i'm hoping to upgrade to 10 cells so it would be good if the esc would be acceptable of 10 cells).
Old 11-07-2003 | 10:27 AM
Rainman-ACRF's Avatar
Default RE: microjet esc...
I have both of these models and they are huge fun (though not really jets, this thread really belongs in the foamie/electric section).
I would have to advise on the Twinjet, as with the Microjet weight is everything and decent batteries in something that small are a problem. Suitable batteries for the Twinjet, either 8 x sub-c cell or 10 x sub-c cell are in good supply and relatively cheap. On 8 cells the Twinjet flies well, on 10 cells it's good, even on the stock permax 480 motors.
If you want to have REAL fun then get yourself a couple of 400 size brushless motors and a good 40+ amp rated speed controller. I recommend a pair of Kontronik "Fun 400-23" motors with a Kontronik "Smile 40-6-16". Get some prop adapters and use either 5.5"x5.5" or 6"x4" props. On 8 cells that setup will go vertical from launch and on 10 cells is a veritable electric missle. This setup isn't cheap considering it's only an electric foamie, but you'll surprise everyone at your flying field when this little electric foam jet blows their IC trainers into the weeds and gives a good 12 minutes flight time on a 3300mah pack (8 minutes on continuous full throttle). Trust me, you will fall in love with your Twinjet as have many people. They have a really long glide and fly really, really, well. There are many mods you can do to them and some have been clocked at approaching 100mph. Apparently, the ultimate setup for the Twinjet involves modifying it to take a single 500 size brushless motor mounted centrally and a 10" folding prop.
With a few battery packs, a leisure battery and a decent quick charger you can have a whole days worth of fun at the patch and not have to worry about fuel and mess. If anything happens to your Twinjet then it will be a little more forgiving than a Microjet. It's a little stronger and a little less flimsy. Though with either model they can be repaired at the field with generous amounts of CA in mere minutes.
I've spent some serious money on a whole number of different models (gas turbines included), but I love my Twinjet. I can just turn up with my TJ, a bunch of battery packs and my TX and just go and fly - no hassle!
TWINJETS ROCK !!!
Phil
Old 11-07-2003 | 02:33 PM
Thanks for the great info. However, I'm not really looking to impress people. The information you gave me on the twinjet is great. I've read that it is more stable than the microjet, however I also read that you can get more stability if the battery pack is lighter on the microjet, thats why i was thinking about the KAN 1050's as they are only .8ounces each cell.
I still am not sure of which esc to get for the microjet, as I would still prefer to get it.
And I'm surely not planning on going brushless just yet. Thanks again.
Old 11-09-2003 | 02:34 AM
I was thinking that maybe I should just get the stock setup that multiplex recommends on towerhobbies.com. but the bat pack is only like 500mah, and I really dont think that would be enough for a 4 minute flight... the esc is motor mount too, so i'm concerned about compatibility issues if i decide to get a 400bb
Old 11-10-2003 | 09:56 PM
hey
kotnronik has those rondo esc which you mount directly onto the motor. the 480 goes up to 18A/22A
check out www.kontronik.com
Florian
