 Fuselage crosssections x35/32 needed - please help >
Old 11-21-2003 | 04:29 PM
TIX
Default Fuselage crosssections x35/32 needed - please help
I am looking for fuselage crosssections for jsf x35/32. I can't find anything on the web - can anyone help me.
Tix
Old 11-22-2003 | 01:35 AM
watt_the!'s Avatar
Default RE: Fuselage crosssections x35/32 needed - please help
Try Russ Ahlberg at Oakdale Aircraft..
you do realise that these are completely diff aircraft right?...
Old 11-22-2003 | 08:34 AM
Mike James's Avatar
Lockheed Martin is not giving them up... at least not to me, and I've begged a lot.
Here's my solution:
Buy a plastic display model that you believe to be accurate, then slice it up. I've recently done an article on this very thing, using the F-22 as the example, on my web site at http://www.nextcraft.com/plastic_to_rc01.html
It's pretty easy, and will give you very accurate sections, which even include the interior parts. such as landing gear bays, exhaust openings, cockpit, etc.. You can do the whole process in just a couple of days of easy work.
