Reagle Eagle
My Feedback: (7)
OH
Hey I just bought this F-15 as my second jet. Does anyone have recomendations or improvements to the kit.
BTW I will be powering it with an OS91/Dynamax (already have)and was thinking of using 7 channels- flaps, retracts, and inflight mixture.
Is inlet ducting giong to be of enough benifet to go through the aggravation to make it?
inlet liners will make all the difference. they not only provide the correct path for incoming air but keep that air from becoming a drag inside the fuse.i've actually got an old set i can sell you real cheap.they must be ten years old.if you build it lite and right,those things actually fly well
