Reload this Page >
L39/Wren 44 Pics and video
Old 06-30-2005, 03:44 PM
  #2501
GrayUK
GrayUK's Avatar
Default RE: L39/Wren 44 Pics and video
Dave
Nice to meet you too.
Yes i had to shoot off home to my missus!
How about the inflight shots?
Paul
Old 06-30-2005, 04:02 PM
  #2502
Dave03B
Hi Paul,
Out of all the photos I took, I got very few decent inflight shots of the L39, mostly due to it's size L39 speed + size = photo nightmare.
Got a few of it on finals, which can be seen along with the rest of Saturday's W&W coverage [link=http://www.rc-expertise.com/modules.php?op=modload&name=coppermine&file=thumbnails&album=40]*here*[/link]
An RC-expertise W&W video is being compiled and edited, and i'm pretty sure your L39 was videoed. Any ideas about that final landing yet?
Dave
Old 07-01-2005, 05:53 PM
  #2503
Freff
ORIGINAL: Freff
ALL
My L39/MW44 full autostart is up for sale. Unflown L39 and less than 10min flying on the turbine. PM me for any details photos etc.
A few photos for those who have asked.
ID:	292542   Click image for larger version
ID:	292543   Click image for larger version
ID:	292544   Click image for larger version
ID:	292545   Click image for larger version
Old 07-01-2005, 09:26 PM
  #2504
David Gladwin
David Gladwin's Avatar
Mike,
I think the 361 servo here in Asia /Pacific is the 368 in the US.
Regards,
David.
Old 07-01-2005, 09:54 PM
  #2505
bnova
David,
Thanks for the info. Do you know if anyone has used a slimline wing servo for the elevators. Not sure there is one available that would fit, but was curious if it would be possible?? Did you consider it when you built your second L39?
Thanks!
Mike
Old 07-02-2005, 03:33 AM
  #2506
David Gladwin
Hi Mike,
I haven't built my second L39 yet, but all the parts are assembled ready to start. . No 1 is still flying and I am trying to get my Mig 29 completed !
Sure there is plenty of room for whatever elevator servos you wish but I think the 361s are perfect. regards, David.
Old 07-02-2005, 09:53 PM
  #2507
bnova
David,
I was trying to find out if I could use a JR DS168 http://www.horizonhobby.com/Shop/ByC...ProdID=JRPS168 installed directly in each side of the horizontal stab instead of running the push rods from a single servo in the fuse. Do you know anyone that has done it successfully? I guess my only concern is running the servo wires near the thrust tube.
Thanks again!
Mike
Old 07-03-2005, 12:50 AM
  #2508
David Gladwin
I Think Dave Wilshere did just that. BUT dont forget that this model, mine certainly, needs nose ballast. more weight aft means more weight needed forward, meansd aheavier model !
Regards, David.
Old 07-05-2005, 10:14 PM
  #2509
erbroens
erbroens's Avatar
My L-39 arrived today!!!! I am happy now!
I also runned the W-44 last week in the bench just for test purposes and it worked ok, but this little
engine screams at 190K rpm! never heard nothing like it.
BR, Enrique
Old 07-06-2005, 03:10 AM
  #2510
David Gladwin
Dont worry about the noise at high rpm at close proximity. When the a/c is airborne its actually very quiet !
Regards,
David.
Old 07-06-2005, 03:30 AM
  #2511
smartmove
What order number were you?
ORIGINAL: erbroens
BR, Enrique
Old 07-06-2005, 03:32 AM
  #2512
sengle
Does anybody know what is happening with Vaclavs email? I have tried [email protected] & also [email protected] but both 'bounced'.
Unfortunately I need to order a replacement L39, as I destroyed mine this weekend. It was its 3rd flight, and entirely my fault. DOH!
Cheers from NZ.
Old 07-06-2005, 06:36 AM
  #2513
JSF-TC
JSF-TC's Avatar
Sengle,
I had the same e-mail problems, but he seems to receive them anyway, I had an overnight reply from both my last 2 e-mails to him, both of which appeared to bounce.
Sorry about your loss. Mine only lasted 2 flights. Servo gear failure.
Number 2 is on order.
Paul
Old 07-06-2005, 06:59 AM
  #2514
Dave03B
Don't worry about the noise, although I'm still to experience the noise from mine, I have seen and heard Mr. Gray's L39 fly, and, as David says, it is very quiet when up there!
Old 07-06-2005, 10:38 AM
  #2515
erbroens
erbroens's Avatar
David G. and Dave03B: the noise is not much a concern, I liked it!!! althought this little one didn´t have the rumble of a big block engine, it certainly has a high pitched scream that is pretty impressive.... as you said, it should be lower at a distance and with a concealed installation.
Smartmove: I am # 19/2005 and it arrived yesterday with a friend´s # 20/2005. they were sent last week from CZ..
Sengle: sorry about your crash... don´t worry about Vaclav´s email issues. they bounce but
they work.
B. Regards, Enrique
Old 07-06-2005, 08:52 PM
  #2516
H.Dale
I have a couple of questions. I received the Spring Air gear for my L39 yesterday. The main gear mounts are wider than those molded into the wing. Did anyone else have to cut into the wing to make them fit?
Also, what is the preferred method of attaching the stab? I know there are several examples using screws or cotter keys. Did anyone just glue the stab on?
Thanks.
Hal
Old 07-06-2005, 10:07 PM
  #2517
Gary Arthur
My Feedback: (29)
Gary Arthur's Avatar
If I remember, one wing had to have the gear opening enlarged a little more than the other.
For the stab, just put a screw ito each and into the CF tube from the bottom. It will be removable. If you go the permanent route, you may regret it if you have any problems.
Old 07-07-2005, 02:02 AM
  #2518
volkan
have you seen the videos yet paul?
Old 07-10-2005, 03:38 AM
  #2519
J.F
Colour Codes
Does anyone have the colour codes for the red and white shown in the pic?
James
Old 07-17-2005, 03:55 AM
  #2520
David Gladwin
Another L39 arrives. This new one is that of Rick Butnaro in pseudo RAAF markings to compliment my "RAF" version at Maitland, NSW, Australia. Strong winds prevented the first flight but everything checked out OK ready for its maiden. My machine flew in the winds but landing was not fun. Wren performance in both machine was, as usual, first class.
The fleet grows !
Regards,
David Gladwin
Old 07-17-2005, 01:23 PM
  #2521
GrayUK
GrayUK's Avatar
Volkan
What videos?
Paul
Old 07-20-2005, 07:51 AM
  #2522
Alexdu
Alexdu's Avatar
Hi guys. I just put my NIB L39 up for sale on the marketplace. I was so looking foward to having this plane but unfortunately I do not build and the build quotes I received were too expensive in relation to the cost of the plane.[][][]
Regards
Alex
Old 07-20-2005, 08:12 AM
  #2523
bnova
David,
I received my L39 a couple weeks ago. The wing does not seat flush against the fuse . I have to push pretty hard to get it to seat because there is someting blocking it. Did either of yours require a bit of sanding on the fuse or wing root to get it seat without force? I am sure if I tighten the bolts I can get it flush, but I was expecting a nice perfect fit?
Thanks!
Mike
Atlanta GA
Old 07-20-2005, 08:19 AM
  #2524
JSF-TC
JSF-TC's Avatar
Alex,
Check your ad.
Regards
Paul
Old 07-20-2005, 11:38 AM
  #2525
swissflyer
swissflyer's Avatar
ok...everything is ready...turbine, pipe, carbon pushrods, servos, landing gear, weels, receiver, pilot, tanks, antenna, different hardware...[8D]
now is just missing order 26/2005...
