hitech servos... >
hitech servos...
hitech servos...
Old 05-30-2002 | 12:16 AM
Guest
My Feedback: (73)
Default hitech servos...
Will hitech servos accept futaba servo horns ? if not, which ones can I use ?
WOjtek
Old 05-30-2002 | 09:37 AM
I don't believe they will. I just tried a couple them that I had laying around, no joy.
Cheers!
Bob
Old 05-30-2002 | 10:09 AM
I think Futaba's are different than anyone else's.
Hitec, Tower Hobbies and Hobbico are interchangeable.
JR and Airtronics are interchangeable.
Old 05-30-2002 | 10:45 AM
My Feedback: (9)
there are two hitec servo arms so don't mix them up..the new digitals use an arm with a plus stamped on them and the old ones will fit but are loose enough to strip under load. check out airwild modles for a great deal on alum arms for all servos.
joe
Old 05-30-2002 | 11:09 AM
Guest
My Feedback: (73)
what is the phone # and/or web site for airwild models ?
thanx for the reply. I was going to use century metal arms, I never knew the digitald had diferent dimensions ...
this is worse than connector compatibility ...
Wojtek
Old 05-30-2002 | 02:03 PM
bkf
Wojtek
http://www.airwildhobbies.com/
Old 05-30-2002 | 05:32 PM
Be careful here. Some Tower/Hobbico servos are relabelled Hitecs, others are Futabas.
Old 05-30-2002 | 09:29 PM
My Feedback: (31)
Watch out for these so called "interchangable" servo arms. Although they may have the same spline count, most of them do not have the same major diameter and minor diameter.
What does this mean when you try to "interchange" them ... slop ! Depend on what your applications are, some of you may not care about that little slop. But word of caution ... a little slop will develop into a "big" slop!
Yojedi
Old 05-30-2002 | 10:00 PM
Mike Sieniarecki's Avatar
Default No, only Hitec arms will fit Hitec!
Unfortunately only Hitec servo arms will work. Tower Hobbies and Hobbico servos are private labeled from Hitec and will fit; however, I am not sure if the are selling arms separately.
We also make new aluminum servo arms. Part number 55701 for the 3/4" single sided and 55702 for the 1" double sided!
Just curious...what Hitec servos are you using?
Airwild Hobbies also has great arms for Hitec and other servos.
(714) 751-7588
