Futaba T9CAP program question >
Old 05-30-2002 | 08:27 PM
jetspud's Avatar
Default Futaba T9CAP program question
I need to mix my steering with my rudders. Can anyone help. This Is for my Roo. I have the two rudders servos Y'ed in to channel 4 now the steering will be put in to channel 6. If you could give me a step by step instructions on how to mix the two. It would be greatly appreciate. If you want leave me a number and I can call you to get it info over the phone. Or you can call me. Let me know.
David Elizondo
Old 05-30-2002 | 10:36 PM
lov2flyrc's Avatar
My Feedback: (24)
David,
Turn on radio, press mode/page button for three seconds. once your in the programming page hit mode/page again which will take you to Prog. Mix pages. Select an unused P Mix with the Jog dial, then press the Jog dial to enter mix, down arrow to page two, should set it to look like this:
MIX ON
MAS RUDD
SLV FLP
LINK OFF
TRIM ON
SW ANY SWITCH LETTER
POSI NULL
then down arrow to page one, set rate to about 50 % in both directions and your done!
Todd
Old 05-30-2002 | 10:44 PM
My Feedback: (16)
I don't have my transmitter in front of me so I will do this from memory.
Hit mode until you go to advance programing.
Use the rotory wheel until you get to the PM you want (1-5 only)
press the rotory button to select the Pmix you want.
Use the up/down arrow to go to mix, use rotory to select on
Use the up/down arrow to go to posi, use rotory to select null
Use the up/down arrow to go to master, use rotory to select ch4
Use the up/down arrow to go to slave, use rotory to select ch6
Use the up/down arrow to go to link, use rotory to select on
Use the up/down arrow to go to trim, use rotory to select off
Use the up/down arrow to go to left mix, use rotory to select 100%
(You should hold the rudder stick to the left. As you dial in mix, you will see the steering move.)
Use the up/down arrow to go to right mix, use rotory to select 100%
(You should hold the rudder stick to the right. As you dial in mix, you will see the steering move.)
If you still need help, go to my site and send an email and I will call you
Old 05-31-2002 | 01:37 AM
jetspud's Avatar
Default Thanks Guys
Thanks alot guys that was easy.....
David
Old 05-31-2002 | 10:59 AM
My Feedback: (16)
Make sure you addjust the percentage 100%/50% until you get the throw you want. DOn't addjust the expo and throw of the rudder to get the effect you want on the steering.
DO the steering last.
