 aeropoxy use >
aeropoxy use
aeropoxy use
Old 02-07-2004 | 04:48 PM
My Feedback: (35)
Default aeropoxy use
Should Aeropoxy be used like ordinary epoxy to glue parts together or only as a fillet for additional strength? Can I assume that since this is an epoxy it will not attack foam?
Old 02-07-2004 | 10:48 PM
My Feedback: (44)
Default RE: aeropoxy use
You can use aeropoxy any way you want. I have not tried it on foam thu, but I suspect it should be ok.
Old 02-07-2004 | 11:32 PM
Aeropoxy is an aerospace quality two-part epoxy adhesive. It has excellent peel and shear strength, and is an excellent adhesive for our applications. Like Ehab stated, you an use it anyplace you want. It will not attack foam.
Harley Condra
BVM REP
Team JetCat
