O Ring Dimensions For Ram500r Starter >
Old 06-06-2002 | 08:07 PM
XCaliber's Avatar
My Feedback: (104)
Default O Ring Dimensions For Ram500r Starter
DOE'S ANYONE OUT THERE KNOW OR COULD MEASURE FOR ME THE DIMENSIONS FOR THE O RING ON THE RAM500R?
I returned a bad starter to Ram with out taking the O ring out.
In return I got a new starter with no O ring on it.
I call them & told me they ran out of O rings and that I can get one in a hardware store.
They couldn't tell me the dimensions.
Thanks for your replys.
MB
Old 06-06-2002 | 09:18 PM
That is really Sad !! Might check with Tad at Golden West Models he should be able to help.
Jim Whitney
Old 06-06-2002 | 11:06 PM
Default I have two
Condoe_won,
Dimensions, as accurately as I can take the measurements:
Outer dia: 0.55 inch, or 13 mm
Inner dia: 0.33 inch, or 8 mm
Thickness: 0.09 inch, or just over 2mm
I have two brand new O rings for the RAM 500R that I got from RAM a couple of months ago, just before they forced me to upgrade to the new X starter. I no longer have a use for them, and would be more than happy to pop them in the mail to you first thing tomorrow morning if you will just post your address here. (Or send me email)
If you need the parts faster than regular first-class mail will handle, I'll send it whichever way you wish if you simply give me your word that you will later refund me the cost of the rush shipping.
Lemme know !
BTW, it seems rather odd, that if one can simply "pick an o-ring up at the hardware store" as Ram told you, that RAM somehow was unable to do so themselves... geez. Great little engines once you figger them out, but RAM doesn't seem to be doing themselves any favors on the Customer Service front these days. I sure hope they get that straightened out.
Gordon
Old 06-06-2002 | 11:16 PM
XCaliber's Avatar
My Feedback: (104)
Thank you Gordon,I appreciate your genorosity.
I will e-mail you my address.
MB
Old 06-06-2002 | 11:33 PM
Default On their way...
They are in an envelope right now, just waiting for a chance to drop em off at the mailbox first thing tomorrow am.
Enjoy.
Gordon
Old 06-06-2002 | 11:59 PM
XCaliber's Avatar
My Feedback: (104)
Thank you Gordon,
Better then Ram's customer service.
Mario
Old 06-07-2002 | 02:21 AM
Default 500R O-Rings
Condoe_Won,
Becareful, there are two different sizes of o-rings that they use. I had to replace mine and they sent me both sizes so I would have the correct one. As far as I can tell the outer diameter is the same but one is a little thicker than the other.
patrick.
If you need a pic I have and extra one of each that I keep just in case I need one.
Patrick.
Old 06-07-2002 | 02:28 AM
XCaliber's Avatar
My Feedback: (104)
Patrick; If you could e-mail me a pic I will appreciate it.
So that I can compare the two diffrent sizes.
Thanks, Mario
Old 06-07-2002 | 02:58 AM
Default O-Rings
Condoe_Won,
RCU will not let me send an attachment through their email so I am posting a picture here. The thicker one is what (on the left) I use on the older style (not X series) starter motor and I just checked my 1000R which use the thinner one on the right.
Old 06-07-2002 | 03:12 AM
XCaliber's Avatar
My Feedback: (104)
Thanks Patrick for posting the picture. Now I know that the thicker O ring will work with my RAM500R.
Old 06-07-2002 | 03:25 AM
...and the ones I'm sending you are the thicker ones. As mentioned previously, they are for the 500R, not for a 1000.
Gordon
Old 06-07-2002 | 03:28 AM
XCaliber's Avatar
My Feedback: (104)
Great Gordon, Thanks
Old 06-07-2002 | 03:34 AM
Default O-Ring
Gordon,
Just for clarification......the RAM500s could use either O-Ring depending on what brass fitting they put on your starter motor. My 1000R is an early production model thus it uses the thinner O-Ring whereas the later model 1000R's also use the thicker O-Ring.
patrick.
