2 Jet videos
RE: 2 Jet videos
ORIGINAL: rpmtech
Yeah, First time I have seen smoke with a bifurcated duct, Looks great!
What altitude is that place at?
RE: 2 Jet videos
Hi Staale
I am interested to know what engine you have in the F-15, and what smoke system? - I also have the Skymaster F-15 - with a South African ModelMechanics 12kg turbine.
RE: 2 Jet videos
ORIGINAL: Mi-25
Hi Staale
Hi Staale
I have a 13,5 kg. SimJet 3000 in my F-15.
The smoke system is home made. I used a Hausel turbine fuel pump running on 6 Volt, controlled by a 10 amp. slowflyer speed regulator. Here is a pic of the injector nozzle i made.
#31
RE: 2 Jet videos
Hello
This pictures was taken by Staale last weekend. This is the same Rafael as on the video.
SimJet 3000 AES + power. Aviation Design kit. TamJet bifurcated duct. 4.7 liter fuel.
Regards
Cato Horten
Norway
Regards
Cato Horten
Norway
#34
RE: 2 Jet videos
Hi Staale
I bought retracts & brakes from ARF Comp. in Thailand, and was surprised to see they came from MM - anyhow, they work well except for a little 'slop' on the nosegear...this is probably from their 1st batch..after which I know improvements were made? I had some problems with the brakes initially but sorted that out.
I use the 12kg autostart MM engine, and to be honest have had no real problems with it. Great thrust for this model.
The only drawbacks (for some) at present are that the engine operation is totally autonomous - you have no idea of whats happening inside (EGT or RPM) & that there is no connection for compressed air if you need to cool it from outside - they say they are working on this aspect.
I set the thrust using a pressure gauge connected to the compressor for idle/max.
The question is: why do people want to know whats happening inside? you can't control it, and the controller will abort the start or shut-down anyhow if there is a problem.
MM told me that they are bringing out new controllers in the future that will show various parameters for the modeller.
Cheers
Leon
Cheers
Leon
#35
RE: 2 Jet videos
Hi you all !
Funtastic videos !!! They put a smile on my face !
Sadly i did not see any landings with the Avonds F-16 ! Maybe you have an other Video wich shows some landings with the F-16 ??
I wish you always a handful of air underneath your wings !!
Sincerely
Thomas
( Sixshooter )
Sincerely
Thomas
( Sixshooter )
#39
RE: 2 Jet videos
Cheers Staale,
I can host videos (and pics) for free. thos vids are great and I would love to have them in my site - www.planesandmodels.com
its an rc portal to the israeli rc hobby.
If you would like, contact me via mail and I will give FTP adress you can upload into.
Ziv B.
Israel
[email protected]
Ziv B.
Israel
[email protected]
#40
RE: 2 Jet videos
ORIGINAL: ZivBit
Cheers Staale,
Cheers Staale,
#47
RE: 2 Jet videos
http://www.vfkm.no/flyshow04/
Try this site - just look for names like jets, video etc....
Good luck!
Tor
Good luck!
Tor
#48
RE: 2 Jet videos
Your videos are TOO GOOD!!
(your server however, is not :-) I uploaded them to this site:
[link]http://www.rennison.dk/mfa/flyshow04_jet_torsdag.wmv[/link]
[link]http://www.rennison.dk/mfa/FFL_Jet_Fredag.wmv[/link]
I've seen them 10-15 times now, they rock!
