Bodyslam!!
My Feedback: (67)
Hi Doug,
When did it happen? You forgot to call me for being your spotter. At least I can witness it first hand. Well, your destiny is a real Turbine Jet. By the way maybe we can get a discount for fixing your F-16 and painting my Cyclone, if you can find a pro-builder for us.
Mike
Mike
My Feedback: (80)
Yes I got the waiver sign off before the 16 went to JET HEAVEN.
If anyone is interested? I have 2 OS .91 VRDF engines, JMP tuned pipe, Ramtec Fan with a BVM inflight mixture for sale. The motors run great! I'll let the lot go for $300 + shipping. I don't need them anymore. Turbine only from now on.
Should not have been a glitch. Most likely the servo failed hard over? Is there enough left of the elevator servo to find out? Having said that it should not have been a glitch, years ago, I had one of the early Futaba 8UAPs go hard over on everything while flying (luckily not a jet) with a PCM receiver with fail safes set to straight & level. Never found out what it was. Most likely an internal receiver fault. I should have learned right then & there to dump Futaba, but I'm dense. It took me several more wrecked airplanes and several 9ZAP WCII failures to wake up!
