P120 compressor wheel >
Old 06-21-2002 | 09:08 AM
mick15's Avatar
Default P120 compressor wheel
Help!!
can anyone help me with a compressor wheel for the P120?
urgent
brg mick
Old 06-21-2002 | 06:18 PM
mr_matt's Avatar
My Feedback: (10)
Default ?
If you find one are you planning to try to install it yourself?
Obviously this is not recommended nor authorized.
This is not meant to in any way impune your mechanical skill, but this cannot be done without the proper equipment and training.
Old 06-21-2002 | 07:16 PM
Default P120 wheel
Hello Mick,
I phoned a friend who fixed recently his P120 from FOD, and said me that the wheel is a Garrett T3 446279-0001
69,00 mm Major diameter
51,65mm intake diameter
6,25 mm shaft diameter
Trim 56
Please take this as a suggestion and check if this wheel is exactly like yours. I personally haven't do the replacement.
Regards,
Lou
Old 06-21-2002 | 11:09 PM
My Feedback: (12)
mr_matt
how much can i get a Jet Cat p-120 the cheapest!!!!!!! i hered 2500 is this true or should i go with RAM
Old 06-21-2002 | 11:13 PM
Mr_Matt
The UK is home to the Gas Turbine Builders Association (GTBA), I'm sure they have the skills and tools necessary to do the job of replacing the compressor wheel.
Old 06-21-2002 | 11:24 PM
mr_matt's Avatar
My Feedback: (10)
Originally posted by littlepiston
mr_matt
No question.......
RAM all of the way.
Old 06-21-2002 | 11:25 PM
mr_matt's Avatar
My Feedback: (10)
Originally posted by six shooter
Mr_Matt
Can't wait to see how they re-profile the front of that compressor....
Old 06-22-2002 | 02:42 AM
Hey, a couple of hours with a Dremel.... what's the big deal, right?
Old 06-22-2002 | 03:02 AM
Guest
My Feedback: (73)
perfect balance, thats the big deal ...
Wojtek
Old 06-22-2002 | 03:45 AM
Default cheapest?
I'm with Matt!!
If you want the cheapest--- a yellow shirt and a blue hat may be in your future.
Jason Somes
JetCat USA
D.F.U.
Old 06-22-2002 | 04:14 AM
mr_matt's Avatar
My Feedback: (10)
Default jason
are you guys really going to prado at 7???
I heard you got the bobcat back. They flew that T-37 after you left.....big plane...funny
Old 06-22-2002 | 04:18 AM
mr_matt's Avatar
My Feedback: (10)
Default ,
Wojtek
Very true, but in addition the wheels now are not "stock" any more, so you cannot just go out and buy a wheel like you could with the KJs
Old 06-22-2002 | 09:28 AM
In case you guys did not spot it, I was kidding.
Old 06-28-2002 | 06:16 PM
Robrow's Avatar
Hi Mick, no problem with the wheel, just let me know if you have one or need one fitting.
Cheers, Rob.
Old 06-28-2002 | 06:59 PM
Default missed it
They missed it Mark -- hackles were up -- impairs the senses. Just kidding guys.
Antony
Old 06-29-2002 | 06:06 AM
mick15's Avatar
Hi Rob nice to here from you yes I could use your help please E-mail me
Mick
Old 04-18-2021 | 09:44 AM
good evening, I reopen the post. I am looking for a jetcatp120 turbine compressor. the original compressor seems to be out of production and unobtainable.
are there other compressors compatible with this turbine ??
Old 04-18-2021 | 12:21 PM
ravill's Avatar
Call Jet cat USA or, you being in Italy, Jet cat Germany. They will have an answer for you.
Old 04-28-2021 | 11:34 AM
Xairflyer's Avatar
Its a garrett T350 446279-0001 details I have is
69mm dia
51.65mm intake
6.25mm shaft
Trim 56
Old 04-28-2021 | 02:05 PM
https://www.turbosbytm.com/compresso...l-t350-trim-56
Regards,
