 Rotor Balancing >
Rotor Balancing
Rotor Balancing
Old 05-11-2004 | 10:01 AM
Default Rotor Balancing
Can anyone explain to me the process of balncing a Dynamax DF rotor??? Thanks for all of your help...
Old 05-12-2004 | 01:18 PM
Default RE: Rotor Balancing
Hi Navpro,
Do you know for sure that it is out of balance? You can check it on a prop balancer or a highpoint balancer. It should not be off very much, you can sand the heavy side over a span of 2 or 3 blades but very little. Do not change the airfoil of the blades.
Tom.
Old 05-14-2004 | 09:29 AM
Thanks a lot for the info...
