Turbine controls
Turbine controls
Hello,
I have never flown a turbine powered plane. However, i've been flying prop powered planes for a while.. Im not planning on getting into jets anytime soon. I still do have some questions regarding a turbine powered plane..
For a regular prop plane, we can fly one with 4 channels most of the time unless you wanna' add flaps, speedbrakes etc
I've heard that for a turbine powered plane, you need atleast 9 channels. What are the controls on a turbine? Is it possible to fly it with just 4 channels?
My Feedback: (29)
RE: Turbine controls
Most jets have the following:
1 - throttle
2 - ailerons
3 - elevator
4- rudder
5 - retracts
6 - flaps
7 - wheel brakes
8 - turbine control (some turbines don't have to use this one)
9 - nose steering
options:
10 - smoke
11 - bomb or fuel tank drop
12 - functional canopy
1 - throttle
2 - ailerons
3 - elevator
4- rudder
5 - retracts
6 - flaps
7 - wheel brakes
9 - nose steering
options:
10 - smoke
cant you do this:
1 - throttle /smoke
2 - ailerons
3 - elevator
4- rudder / nose steering
5 - retracts
6 - flaps
7 - wheel brakes
options:
abit easier
1 - throttle /smoke
2 - ailerons
3 - elevator
5 - retracts
6 - flaps
7 - wheel brakes
options:
abit easier
HI
I think if you set the throttle and smoke at the same channel will caused 2 problems. 1. You will have difficulty to see the plane before take off, the smoke will block runway if you don't have another switch to control it. 2. The smoke will run out in the first 1 or 2 min, and you will have no smoke in the rest of 4~6 min fly time.
Depends on the model that you are flying how many channels you really need.
Lets take a bobcat.
1. ailerons
2. elevators
3. throttle
4. rudder/steering
5. retracts
6. Brakes.
or hotspot.
1. Elevon
2. Elevon
3. throttle
4. rudder/steering
5. retracts
6. Brakes
7. Speedbrake (optional)
You don't need an expensive 9 or 10 channel radio to fly jets. BV even advertised the bobcat as a 6channel flyable plane.
Patrick.
Lets take a bobcat.
1. ailerons
2. elevators
3. throttle
4. rudder/steering
5. retracts
6. Brakes.
or hotspot.
1. Elevon
2. Elevon
3. throttle
4. rudder/steering
5. retracts
6. Brakes
Patrick.
My Feedback: (10)
My first turbine powered model, the Super Reaper, was flown on a 6 channel radio, using:
1- ailerons (two channels, one in each port)
2- elevator (two servos Y'd together)
3- 1 rudder
4- throttle (turbine controler)
5- brake valve
easily done on 4 if you Y'd the ailerons and activated the brake valve with full down elevator.
My AV8R uses the same controls as well, but has added flaps for one additional channel.
AJC
3- 1 rudder
5- brake valve
AJC
