Facet Antenna routing and range check
My Feedback: (35)
WA
Would the owners of Facets please advise whether you are using loaded whip antennas or the regular wire antenna? It seems to me that with the receiver positioned as shown on the plan, a regular wire antenna running from the rear of the fuselage hatch to the top of the vertical fin should be quite sufficient. Also what is the approx range with the TX antenna collapsed for a Futaba TX with Futaba PCM rcvr? TKs
My Feedback: (29)
RE: Facet Antenna routing and range check
I don't like running my RX antenna outside the fuse (just a personal preference), so I ran mine in the cardboard tube that the elevator servo lead runs in. If it had range tested marginal then I was going to install a Revolution whip just behind the top hatch. I use a JR TX and with the TX antenna removed I got about 400' range. (I stopped there because I didn't want to go through the barbed wire fence). Maybe someone with a Futaba TX will chime in here.
You're going to love the way the Facet flies.
Good luck.
Good luck.
NJ
Hi,
My reciever is mounted as shown and I run the antenna out the top of the fuse by the back of the top hatch, to the top of the fin, works fine for me. Whip antenna's, IMHO look plain ugly!
BRG,
Jon
BRG,
Jon
ON, CANADA
Hi Guys,
I also did the "out the top, back to the fin" with both my Facets, per the plans. With the 1200 I had to be a bit careful though 'cause the end of the Rx antenna could get a little toasty in the exhaust plume. With my 2400T (essentially the same fuse as the 2300) the end of the Rx antenna stops right at the tip of the fin so I have no worries there.
Both are controlled through Futaba PCM Rx's, but I can't remember what kind of distances I'd been getting with the antenna collapsed. (Similar to Gary, I got tired of walking!)
My Feedback: (35)
WA
Thanks. I will use the wire antenna from back of hatch to vert fin. Waiting for a better weather for maiden flight. This is my first turbine plane.
My Feedback: (35)
WA
I forgot to ask whether you guys think it possible for the Facet 2300 ( powered by Simjet 1700) to take off at my current club field runway which is 300ft long that has a rubber/felt type runway surface? Its a bittle bumpy though. Tks
My Feedback: (29)
A friend of mine was thinking about powering his Facet 2300 with a JetCat P70. So just for grins I tried a takeoff with my P120 only turning about 102,000 (between 17 & 18#). It lifted off in about 250 - 300 feet off of grass with no flaps.
Good luck.
Good luck.
You should have no issues flying the 2300 from this hard surface with the SIMJET-1700.
You can expect good soild flight performance with the SIMJET-1700 installed and I would expect to see a ground roll of less than 200 feet on T.O. from the surface you have discribed.
Good Luck Jeff.
Good Luck Jeff.
