Jmp /yellow Starfire Help
Ok Vinny, ya' had me looking under piles of retired aircraft parts for the instruction manual for the Y/A starfire but here goes the specs are as follows:
Elevator travel 3/4" up 3/4" down
Aileron travel low rate: 3/8" up 3/8" down
middle rate: 1/2" up 1/2" down
high rate: 3/4" up 3/4" down
Flap deflection 35 deg. max
Rudder travel 1" left 1" right
as for cg I have to look for another couple of days for the plans because that's where it is mentioned either if I find it by Saturday I will bring it to the field-- if you will be there---
btw---when is this bad boy coming out??
Lee
Lee
My Feedback: (37)
WA
JMP Starfire CG
CG is six and a half inches behind leading edge of wing at the root. Also, three quarters of an inch behind the main wing spar former, measured from the rear edge of the spar.
