Skymaster F15 Video
My Feedback: (24)
Skymaster F15 Video
Managed to get some video of my new Skymaster F15 on Sunday..... Not a full flight since my camera man ran out of tape but here it is anyway.....
I believe this is flight #6 for this airframe.
Hope you enjoy...
Todd
[link=http://www.lov2flyrc.com/Video/F15.wmv]F15 Video [/link]
Hope you enjoy...
Todd
My Feedback: (102)
RE: Skymaster F15 Video
Very nice Todd,
My F-15 took wings this weekend as well, and looks to be as great a flier as yours. I think my engine must not be as conservative as yours, At 7 minutes I think the tank would have been just about dry. Good video, thanks for sharing.
Tommy
Tommy
My Feedback: (38)
WA
HI Todd
Nice vid on ringing out the F-15 . What is your dry weight and how hard was you working the P-120 ? I love my Skymaster F-15 , its the taileron only verison , with a Ram 750 for power .
Charlie H
Charlie H
Hey Todd, great vid. man!! I'm fixing to get one too, with the JC p-120.......I was just currious, I'm gona be flying off of grass, and was wondering if that was a full throtle takeoff or partial. Man, I hope mine flies as good as yours, she a bute!!!! Thanks for the info and keep the dirty side down!!
My Feedback: (102)
Mine has only been flown from asphalt, but one landing was more of an arrival than a landing, thanks to too much flaps. I went over to the plane fully expecting to see loose gear mounts, or something knocked loose. No damage. The plane is very well built, better than 90% of the builders out there would be able to reproduce in the time and money that is involved here. I don;t think you can go wrong with this plane. My 750 is putting out around 24# of thrust, and she still gets off the ground with no probelm. Most of the flights have been at a comfortable half throttle. It is very responsive and will slow down, actually too quickly, if you are using the flaps. I won a gift certificate at TNJets this weekend and am probably going to order another one just to "scale out" will a different paint job.
Tommy
Tommy
My Feedback: (24)
Hey Guys....
This is the Taileron only version as well. Using power management I can squeeze 8.5 minutes from gear up to gear down with enough for one or two go-arounds. I have not weighed the aircraft yet but will asap. Takeoff is always full throttle and like most F-15's does take a bit to get on step regardless of power. The armament does add a bit of extra drag which will also extend the takeoff run a tad. I have flown the skymaster F-15 on a P-80 (ail/flap version) and the P-120 and top speed appears to be the same with better vertical on the 120. As tommy mentioned, the gear mounts are very stout and will handle rough grass/landings with ease. I see no issues flying this plane off gass runways although I would suggest the flap version to assist the takeoff run.
Regards,
Todd
Regards,
Todd
My Feedback: (73)
with the f-15s layout, flaps on landing will add more drag than lift ... the plane will climb out better without them, when the plane is still nose down, the flaps act as airbrakes, and if anything, pick up the rear end, making rotation harder to .. (takes longer to get the nose up )
Wojtek
Wojtek
My Feedback: (18)
CA
Very nice Todd. The Skymaster F-15 is a very impressive bird for an ARF. They seem to fly very well.
BTW is that a short field or is it just me?
My Feedback: (24)
Depends what you consider short .... 600 x 48 I believe..... Yes, I wish it was a bit longer but it does the job. only use 1/3 of it for the euro Nice flying site, probably the best site in the state of florida. Too bad I have to drive 1 1/2 hours to fly there []....
My Feedback: (18)
CA
Yeah it looks really nice. I didn't notice the length when I watched the Euro fly, but in the F-15 video I saw the end on take off. I wish we had a grassy, shady place to fly here. I do have a 4000' runway but it is surrounded by desert and is HOT!
My Feedback: (24)
Hey Keith,
The SM F15 flies very well on a older P-80 (17lbs) so performance on a P-70 should be the same with the benifits of less weight and better fuel consumption ....
I think the P-70 would be a perfect match for this plane.
Todd
Todd
