Waco Weekend
My Feedback: (8)
Waco Weekend
Hey Guys and girls
Anyone up for a weekend of jet, helicopter or whatever flying in Waco the weekend of June 26 & 27. Checked with Max and nothing is going on at the field that weekend. Pizza party Saturday evening, my treat.
THIS IS NOT LIMITED TO JETS. Bring your Zagi's and P B G's.
RE: Waco Weekend
Dave,
If your piloting skills could keep up with our mouth, you could hit the old runnway with the Rhino w/o problems. Hell, if I can do it, I bet you could...especially w/o bleachers! Just kidding. I know you can...you are just having too much fun with that KC/p200/p160/p120 or whatever it has on it now. I have a spare P80 if you want to try!
Seriously though, that extension will be nice for those of us that couldn't hit the old runnway with a Bandit.
Later,
Mike J
Later,
Mike J
RE: Waco Weekend
Mike,
A Bandit on the old runway was easy! I am sure I would have no problems with the Rhino and the old runway, I just like that extra margin with any of my scale stuff.
DR
DR
RE: Waco Weekend
Dave,
Not for me. I am having a hell of a time with the bandit on shorter runways while the F4 is relatively easy to hit a smaller runway. Not sure why. Maybe the F4 is just a hell of a plane! I look forward to chasing you around the skys of Austin next year. Maybe Vernon will have his ready by then.
later,
Mike
later,
Mike
My Feedback: (7)
TX
RE: Waco Weekend
mike
>>>> I am having a hell of a time with the bandit on shorter runways while the F4 is relatively easy to hit a smaller runway. Not sure why>>>>>
a bandit ....roo...or hotspot glide much better than a f-4 or f-18.....with your f-4 or our f-18 you HAVE to fly it down to the ground with power and manage your decent with the throttal ...at a few feet off the runway at the #1 wire you just level her out and slowly pull off the remaining power and flare her just before the wheels touch....nuff said
now the bandit...roo ...or hotspot is a guesing game in the 3rd demention because they glide so well ( thus harder to land than an f-18 or f-4)...with these glider type of planes you have to guess your speed way outside of exact visual perception...in other words cut the power....errrr somewhere out there ...which btw changes with headwinds..now what exactly does "cut the power " mean...chop it all together or chop it and see her decending then feeding some back in to get her on your desired glide slope..that being said if you dont manage her properly on final its very to possible to have a 20 mph higher speed than you thought......here is where some pilots panic and put her down anyway .....while still at flying speed.....thus the famous kangaroo hop....where the bird is not ready to stop flying yet but is being forced to land..........if the bird is not "set down " gently and is droped from 12 inches she will leap back up into the air ....and then the pilot says **** and rams the elevator home as if to say "i said land " where as the bird`s response is fu$k you charlie and she leaps again inot the air....all this is happening and in the back of your mind you know your running out of real estate...so once more you ram the elevator before you run off into the grass and rip out the gear...this continues until she is out of flying speed....so goes the kangroo hop
now the bandit isnt a hopper like the roo ( while they still can as any plane) ...the bandit ( if you miss the glide speed on final to much to the high side ) is a wing walker...but it is not iniated the wing tips..it starts at the elevator while flaring in an attempt to slow it down....the elevator "catches a tip" ( they are really slung aft on this plane ) which in turn pulls the whole side down to the runway until the wingtip hits......instinctive stick correction and "wing tip bounce" added together means she will walk over to the other wingtip and so on and so on until she is out of flying speed
now the pisser to get some guys mifted....maybe.....all this is exacerbated by throttal lag...the slower your throttal lag is ...the worse it can get....at least until you get the lag time management down.....
quite frankly these are jets and stay aloft with power and quickly decend without it ( unless you have a semi glider like a roo, hotspot or bandit ).... so in thrust we trust to fly and to land you just remove the thrust and the plane becomes a brick...the key is to remove the thrust a foot off the runway
RE: Waco Weekend
Gregg I hate to disagree, I took a lot of Vernon's Spot landing money with my Bandit! Put the speed break down and fly it to the runway just like an F-4. It just takes practice! The secret is getting the airplane slowed down enough in the pattern where you are applying power to bring it in. Attitude controls airspeed, throttle controls altitude.
My Feedback: (7)
TX
RE: Waco Weekend
david
>>>>Put the speed break down and fly it to the runway just like an F-4. It just takes practice!>>>
yea your right but another thing to think about.....all planes arent equal.....meaning for example on one of our hornets there where 2721s on the flaps......and the plane has large flaps....when deployed at say 80 mph they where not 100% down but trying to..... thus when the plane slowed down enough for them to deploy it would REALLY SLOW DOWN FAST thus causing paul to make some throttal changes....since the make over we put in 8611s....now at 80 mph she slows as commanded which eliminates said throttal adjustments and it lands easier than before.......btw when paul flew our hotspot he deployed the speed brake on the downwind ......on final i asked where is the speed brake....he said its up..i said no its not....he lamded it hot as a mother and upon roll out ....it finally beat the wind and deployed.......thus exit one chicken shi$ servo and enter a 8411...now when he says stop it stops.....point im making is some might watch you land and say im going to do the same thing .....problem is they are under powered with their speed brake servo which increases all the problems for them......and dont forget the geometry...the same servo with poor geometry is like having half the servo power
ttyl
gregg
ttyl
gregg
RE: Waco Weekend
Hey Pat...I flare the F4! Just not all the time. However, I do know how to avoid the pilot safety fence...do you? Man I hated to see that thing hit it. Is it fixed yet? only a few weeks until Odesa, so get to work.
Seriously though, Gregg, the F4 is great cause if I come in hot and slam it down, it rarely will bounce. If it does, it sticks after the first bouce with NO damage. If I do that with the Bandit, the plates are toast. I have found that if I bring the bandit in with power on, I can land it pretty well. Problem is when you are flying on 425 to 600 ft. runnways. Hard to chop the power when 1 ft. off the deck and not run out of space. I'll have a chance to practice more in Addesa in a few weeks.
Mike
Mike
RE: Waco Weekend
I can honestly say I have hit everything BUT a fence!
Gregg,
You might want to rethink using digital servos on the big barn door surfaces like flaps, and speed brakes. They'll suck a battery pack into oblivion very quickly while they try very hard to keep the surface exactly where you want it.
Gregg,
