Mick Reeves Super Reaper building
Hello,
I am starting a Mick reeves Super Reaper here
http://www.rcuniverse.com/forum/m_19...tm.htm#1907914
any coment and tip from you turbines guru would be greatly apreciated
thanks a lot
thanks a lot
RE: Mick Reeves Super Reaper building
I builded the fuselage sides and I am drawing some ref lines, please can you confirm me the recomandes position for the thrust line one inche above the cam.
do you have good results with that position ?. I will fly it with a 12lbs thrust turbine (mw54)
AB, CANADA
It is super easy to build.....the trick is to lay out all your plumbing, turbine wiring, brakes, and radio gear and get it to fit in some semblance of order...there is a lot of room inside, but it gets used up very quickly.
One tip - reinforce the vertical fin mounts...some guys have had them loosen in flight....
