 Hotspot CG/elevon question. >
Old 07-06-2004 | 05:10 PM
Robrow's Avatar
Default Hotspot CG/elevon question.
Hi just a quick question for all you Hotspot Jocks.... how much 'up' elevon do you have dialled in with the correct c of g to fly level ?
I think mine may be too far forward having around 7/16"(10mm) 'up' measured at the root.
Rob.
Old 07-06-2004 | 09:29 PM
Default RE: Hotspot CG/elevon question.
Rob, 10mm sounds like a bit more than usual. My hotspot in very heavy(smoke ,bombs,) more to the nose than tail but still around 8mm. I suggest you recheck the CG. Your probally on the nose heavy side. Scott
Old 07-07-2004 | 09:10 AM
Yes.........perhaps a little nose heavy. My HotSpot measures 5/16 for the reflex.
best regards,
Kim
Old 07-07-2004 | 09:36 AM
Have just got a 2nd hand part-built Hotspot myself - where is the C of G??
Also what method did you guys use for joining the wings??
Jason
