Retracts for a newbie
My Feedback: (7)
TX
I have a set of SA 101HD's setup on a piece of wood. All plumbed and filled with 110 PSI of air. It takes 6 - 10 seconds for them to retract, and it barely does it. I do not have any restrictors in place at all.
Is this normal? What did I do wrong?
With 110 psi they should retract so fast that they would try to rip themselves off the board. There's got to be a restriction somewhere. Is the valve that actuates them the "toggle" type or the push button type?
Johnny
Johnny
My Feedback: (7)
TX
It is the push pull type.
Here is a video of them opening and closing @ 120 PSI and only the mains are connected, nose gear is not connected.
It is about 2 meg.
Click here for Video
Donald
It is about 2 meg.
Donald
My Feedback: (10)
I would suspec tthe valve, the sping air types normally just use a simple toggle valve, perhaps you have an adjustable valve, or have the valve hooked up wron?
I agree with the other guy, at 110 PSI, with the gear mounted upside down like you have it I would be afraid of bending the frames they would snap so fast, be careful!
My Feedback: (47)
FL
Spring Air has a very good retract. Even tho this setup is temporary I would not use only one screw for the frames.
What you need to do is simply pull the lines off each retract and hook your pump to the retract direct and see if it retracts properly. I think matt is right and you will find the valve is faulty. Just give Bill a call and he will send you a replacement.
IT LOOKS QUICKER THAN 6-10 SECONDS.. THE STRUT LENGTH IS EXTREMLEY LONG AND IT APPEARES YOU HAVE BVM WHEELS OR ALUMINUM WHEELS W/ SOLID TIRES... LOT OF WEIGHT AT THAT MOMENT ARM... I WOULD REMOVE THE STRUTS AND WHEELS AND CYCLE THE RETRACT BY THEMSELVES..SHOUD BE MUCH QUICKER..
IF NOT THERE MUST BE SOME TYPE OF RESTRICTION... I WOULD BE SUSPICIOUS OF THE VALVE OR PERHAPS A TEE FITTING THAT IS NOT CORRECT DIAMETER..
GOOD LUCK, LET KNOW WHAT YOU FOUND!!
DAN M.
DAN M.
My Feedback: (7)
TX
It is quicker thatn 6 - 10 seconds when I have only 2 hooked up. If put all three on it is even slower.
I don't have a pump other than a air compressor at this time. I did hooked up all the hardware with just one retract and it is stil slow to me compared to others I have seen here. I can turn the board upside down and it will sometimes pull the wheels up all the way, but rarely.
My Feedback: (20)
Check your T connectors especially the one between the valve and the tank. I ran into this type of problem few years ago and now all I use are the Robart Quick Tees. (See http://www.robart.com/pages/airsys.html item #226)
CA
Ghost:
What was wrong with the 'T's you used before? Were they the old 'plug inside the line' style? How did you know there was a problem, etc.? Why are the Robart 't's better - just curious for my own information (not doubting you).
Dennis
Ghost:
Dennis
My Feedback: (20)
Ghost:
Dennis
Ghost:
Dennis
If during the process of fitting the line into the 'T's, you can mistakenly bend the 'T' if you apply too much force resulting in a kink that will restrict airflow.
I switched to ROBARTS because they are very simple to connect and disconnect just like the FESTO we use for turbines. The only disadvantage is that it is a little bulky but you can easily anchor it down using the two holes provided.
I have replaced all the 'T' in all my airplanes with it and so far, it seems to be working great.
Should you have more questions, please do not hesitate to ask.
My Feedback: (7)
TX
Well thanks for all the help I believe I have figured it out. I took everything loose from the valve and filled her up to 120PSI, and retracted the gear and I can a slight air hissing noise. So it appears that the valve is not letting enough air though. So I called and talked to Bill at SA and he said they where having troubles with that style valve and they had went back to the old style. He said I will have a new one in a couple of days.
Donald
Donald
The button valves SA has been supplying with their retract systems are a POS. The "old" toggle valves (from Clippard) are the best. If Bill has trouble getting one of the toggle valves to you let me know and I'll donate one to the cause.
Fwiw, in a nonscale application of SA 'tracts without gear doors, I like to use restrictors on the up cycle only and allow the air to bleed off unrestricted when the gear is extended. That approach allows the gear to come down right NOW but won't retract with too much force.
Mike
Mike
My Feedback: (7)
TX
So MrMike, how do you set them up that way. Would all the restrictors be between the tank and the valve so that they are not restricted going down?
Bill said he would ship me one out, and I should have it in a couple of days.
Donald
Donald
dneisler wrote ...
Yes. For gear extension that allows the air to be dumped from the retract air cylinders direct to atmospheric with nothing in the way. I've found that just one of the Robart (brass,inline) restrictors slows the up cycle to my liking.
Mike
Mike
