6Volt RX pack?
TX
I know some servos are not rated at 6v, so a regulator is needed. I've used the Mini Hobby regulator with good luck, just make sure you plug it between the RX and Switch. If you plug it between the BAT and Switch, it will drain your pack.
That being said, I know guys using straight 6v packs without regulators and they seem to have no problems. I just started not using a regulator with my 6v pack and so far so good.
JR Gautreaux
JR Gautreaux
1 Post
I use 'em and they're fine
With regulator you'll get a constant voltage straight off the charger. Without regulator you may get a bit of servo 'jitter' whilst the pack voltage is still very high straight off the charger - a bit of stick waggling to take the sting off the pack and all is well.
You'll also get the benefit of maximum torque and speed over 4.8v
Very few servos nowadays won't run off 6v.
Rgds,
Mark
Rgds,
Mark
My Feedback: (60)
I borught that very question to Horizon Hobby last year. I was considering running a six cell pack in my airplane. So I asked if I could run an 8411 at 7.2 volts. His response was NO!! Don't do it. Then to add some insult to the guy I said, wait a second, when you charge a 5 cell pack it charges sometimes to well over 7.5 volts, so why can't I run a 7.2 volt pack.
He then put me on hold to consult with more knowlegable people.
The answer came back "no more than a five cell pack".
So you are good on a 5 cell pack charged to whatever voltage it will hold at least on JR's servos.
Sean
Sean
My Feedback: (24)
WI
2 years and couple of hundred jet flights with 5-cell Nicad Packs..no regulator....One battery......(2) 18 ga battery leads into 2 HD switches into 2 separate inputs on the RX bus......zero problems using JR 940, 945, 950, 955 RX, 53 and 72 MHz, with 8411, 8611, 4721, 2721, 4321, and mini servos like the 341........i.e no jittering and excellent range check.....I prefer SR Nicad packs......just a personal preference........the SR 2200 Series sub-C packs I use actually cycle out to 2700-2800 maH when they are new......
Tom
Tom
I work for Horizon Hobby, and am on Team JR....
FWIW, personally, I run 5 cell unregulated on all my jets... No problems... Many HH employees also do this.
I think it is a personal choice... If you are careless... for example....
You rig something with a stalled servo, or have a gyro gain somewhat high, you may run into problems faster than you would on four cells... I choose 5, for the power, speed, and voltage headroom.
Regulators are fine, but without doing my own testing... They may possibly generate rf noise (since they may use square waves that can have some high frequency components), let us know if anyone has tested this, and they are something else that can fail.... more wire, etc.
Therefore, personal choice.
David
David
I have two (2) 6V 2000mah NiMh packs on my CG Sukhoi. No problems. Don't use a regulator. Hitec Servos..... 605's ailerons, 645 Rudder, 77BB on elevators.
This is my first time using this setup....... still monitoring it closely for problems, but I am very confident of the setup.
ORIGINAL: HotelSierra
I have over 175 flights on my Viperjet with (2) 5-cell 1100 mah packs and have had no problems whatsoever. I am also using the JR 3421s on the elevators.
Gordon
My Feedback: (34)
ORIGINAL: Gordon Mc
Maybe the gyro just causes them to move much more frequently than Joe User does when he wiggles the sticks, such that the "active cycle" is too high to allow the components to remain cool ? I know that I lost two sets of 3421's that way, David Reid and one of his buddies also lost two servos apiece, and Harley Condra's 3421's melted their way out of their cases if I remember correctly.
Gordon
Gordon
Hi Guys
In the old days, who can remember
, 4 dry cells were used in the reciever - this gave a total of 6 volts to receiver and servos. 5 x 1.2 volt= 6 volts so there should be no problem as long as its nicad or NiMh(1.2 volt per cell).
Poly cells are different and will definitely require a regulator.
I have used 6 volt 5 cell packs for the last 8 years on DF, Large Scale and Turbines and have had no problems.
, 4 dry cells were used in the reciever - this gave a total of 6 volts to receiver and servos. 5 x 1.2 volt= 6 volts so there should be no problem as long as its nicad or NiMh(1.2 volt per cell). Poly cells are different and will definitely require a regulator.
ORIGINAL: Zaney1
Gordon
