Roo Gear
My Feedback: (22)
AZ
Roo Gear
I am building a Kangaroo for a friend.
He gave me the kit along with a set of Spring Air retracts.
It has a Sophia J850 turbine with it.
We will be flying from a 600' Grass strip.
I already installed the Spring Air's before I found this wonderful forum called R/C Universe.
I have heard that the Spring Airs won't hold up to grass strips. Is this true?
Should I remove the Spring Airs and get a set of Robarts?
What part numbers do I need to order?
What about brakes and wheels?
Barry Finck
Grantville, PA
Barry Finck
Grantville, PA
ROO gear choices
Hi Barry...The question is not if they will work or not on grass because I have seen em used and used em myself on grass, they work great...the question is how much maintenance do you want to perform when you have a mishap...the Spring Air (although heavy duty strut) will bend a bit with little abuse on landing especially if the field is ruff...I have not found this to be a problem but it does change the way the ROO looks sitting on the ground. If you...say run off the end of the runway into some other type of surface, like a plowed field or such ...well then you have some re-shaping to do. Have fun! :-)
Having said all that...my choice is still the Robart style strut ...Beefy...
Scott Strimple
www.rcairworld.com
[email protected]
PS...I am ref. the Spring Air 702 series gear.
Scott Strimple
www.rcairworld.com
[email protected]
MS
No SpringAir
Barry,
I agree with Todd, ditch the SpringAirs. My sons and I fly a lot, and I can tell you they simply won't hold up to the stresses of even the best landings on grass with a plane the weight of the Kangaroo. Even running off the end of an asphalt runway onto grass will bend them. Before I changed to the Robarts from Planes Plus, I carried an extra set of them with me if I went to an event just so I wouldn't be grounded.
After I changed to the Robart gear, I have had no more problems through more than 300 flights.
What type wheels and brakes are you going to use? I used a set of BVM Sabre wheels and brakes that I already had. I had to mill out the brake hub to 1/2 in. in order for them to fit the Robart strut, and they work great. Don also sells a wheel/brake set to fit them.
Dennis Lott
Dennis Lott
