ziroli f-9f with wren mw54?
Just wondering if anybody thinks the mw54 will be enough power to push the ZIROLI f-9 (built light) through SCALE flight maneuvers? I do not wanna fly 200. Thanks.
F9F
Hornet 1788, As long as the AUW of your Panther stays reasonable eg max of 20 lb or so you will find the Ziroli Panther will perform fine on a MW54 turbine of about 11lb thrust. The Panther has a lot of wing area and will fly fine off a sealed strip... this jet model flys on the wing very well, and does not require excessive thrust.
Although grass field operations maybe more suited to a 18 lb - 24 lb class turbine...
My Feedback: (61)
Panther power
I have to assume you have a Wren at this time?? If not then there is no question you should be buying a P-80 or any 17lb thrust size motor for that jet. The wren will fly the Panther when all things are perfect but on some very hot day or when you blow an approach and need some steam to get out of trouble you ain`t gonna have it, then the famous "snap" and crash follows.
My 2cents only here,
Vin...
Vin...
FL
Ziroli Panther
A friend of mine (Larry Noble) is flying a Ziroli Panther powered by a RAM 750F. In order to fly it at a scale-like, comfortable speed, he pulls the throttle back to about about 30%. It likes full throttle for take-off, but needs to be throttled back for the remainder of the flight. Full throttle isn't even necessary for the vertical stuff, and the airplane is quite happy with that power. It didn't want to get more than a few feet off the ground with the ducted fan, but with the turbine conversion, it is a totally different airplane.
With a Wren, it might be underpowered if heavy, and of course the take-off roll would be longer than with a larger engine.
The airplane has an acre of wing, and is great in the pattern....slows down quite nicely.
This is Larry's first turbine airplane, and he is doing very well with it. It flies like Phil Kraft's Ugly Stick!!!!!
It's up to you, but I would go with the larger engine for that airplane......................there is no replacement for the thrust you didn't install...........
Good luck
Harley Condra
BVM REP
RAM REP
Good luck
Harley Condra
BVM REP
RAM REP
Ziroli F9F
I have only the highest regard for Nick and his designs and the statments reflecting that the Panther flies on the "wing" is well founded.
Having seen the Panther fly many times on a .91 D/F set-up which yeilds 11+ lbs thrust at best, I feel that the 54 will work ok as long as the final ramp weight (WET) comes in at <20#.
However, as it has also been mentioned, you may come to regret not having more thrust on those 85 90 degree days. Turbines like piston engines, will produce less thrust in hot, humid weather and if flying off grass strips, performance loss will be very noticable and pronounced.
Best regards:
Kerry J. Sterner
SIMJET of PA.
[email protected]
Best regards:
Kerry J. Sterner
SIMJET of PA.
[email protected]
Panther weight
Kerry, you said it! I have seen these models fly fine on the OS91 Ramtec set-up, and they will fly well off of short grass fields if you have a lighter model. Also I have seen them fly well with JPX 240P, and Sophia 450 power with ease...
If I was to decide to install a 11lb thrust class turbine eg PST 600 or RAM 500 for instance, it would be only realistic to expect good performance if the Panthers AUW was say under 20 lb. between 15-18 lb is ideal, this lower weight is quite possible to achieve while building if you are planning on a smaller turbine to be installed....Also this is easier with a glass fuz instead of built up fuz. I am fortunate as I just happen to own a set of moulds for this fuz. And my glass Panther airframe assembled with wings/tail and retracts, less paint the engine and radio gear weighs only 8.5 lb.
Here's a comparison of sorts! (similar airframe designs) Tam has been experimenting with the new D.L. ARF Aermacchi and he is flying his model at approx 21 lb AUW! with a RAM 500 for power. Tam has added a smoke system as well and numerous mods to improve structural strength for turbine use.
Keep in mind this is a much smaller model with much less wing area than the Ziroli Panther.
Tam reports the Aermacchi performs very well indeed despite the higher wing loading also apparent vertical performance is very impressive as well, all from an 11 lb thrust turbine....
That said with hotter conditions and adverse wind etc. it is nice though to have plenty of grunt on hand if need be....Although maybe I would not fly my pride and joy in extreme conditions anyway : )
In a nut shell the Panther 'WILL' fly well on the smaller turbines ala scale, 11- 12 lb thrust, and they fly very well on the wing! about as cub like as a jet could be... after all Nick designed this bird to fly on D/F power of only 9 lb thrust approx.
Hi guys,
This is my Panther, a kit from Europe (Denmark or Norway .. not sure) and about the size of Ziroli Panther. Fiberglass fuse and foam/balsa wing, flying weight 11kg. I fly this jet with PST J600 5.5kg thrust (12lbs) for a very scale flight capable of large loops, split S, and almost two vertical rolls. I have also flown the same jet with SimJet 2300 with just a bit better performance but about 1.5kg more flying weight with less flight time.
Turbine mania!
B777
Turbine mania!
B777
MW 54 in the Z. Panther
I saw Foresst's fly at Missouri Valley. It flew nice with this combination and can take off in less than 300'. It was one of my favorites to see fly....I like scale stuff.
If you're into speed I'm sure this isn't the plane or engine, but it looks niiiiiiiiice.
Jim
Jim
replies
Now you all have me thinking. I was looking into getting a used ram750 or p-80 but damn they are so $$$$$$$. I could definetly see spending the money on the wren 54 new at 1400 auto start. Anyhow, i live in PHOENIX, were the temp everyday approaches 115 in the summer, what do you think now? I WILL build it light. This is going to be my first built up jet, and am curious as to where the places are that you can lighten, and where they ar not. For instance, the ribs in the wings, WOW they are big, with alot of 1/8" wood, can i lighten hole these abit. Well hopefully i can get some help. Thanks, Nick
My Feedback: (101)
MVJS
The MVJS...Missouri Valley Jet Scramble, is ooone of the larger jet flies held in the Midwest. It is held south of Omahe Nebraaska. We had roughly 35-40 pilots theree this year including Foressette and his Panther. There are 2 postings here on the list referencing the MVJS. In case you are interestedour web site is www.MVJS.COM its a ggret time and lots of great flying.
F/G Vampire
Hi Mike:
I have not spoken to Mark Frankel on lately this subject tooling but will do so and post.
On the subject of the Ziroli Panther, I spoke to Nick Jr. on Sunday Morning as he was vacationing in my area and we discussed the relaease of a fiberglass fuselage and wood wing kit for the Ziroli Panther.
Nick has a plug in progress and it would be a very good idea if any and all folks that have an interest in obtaining this item, contact Nick by PHONE as he does not track e-mails, and urge him to fininsh the Panther Tooling.
As some of you may remember, there was a "previous" mold for the Panther by Nick Sr. but it was given to Bob Walker of Robart several years back and several attempts to purcahse it by Rei at RAM fell thru.
You can contact Nick Jr. @ 614-467-4765 (Ziroli models)
Regards
Kerry J. Sterner (Vampire)
SIMJET of Penn.
[email protected]
Regards
SIMJET of Penn.
[email protected]
