Turbine Power >
Turbine Power
Turbine Power
Old 07-20-2002 | 09:50 PM
Default Turbine Power
I know that the use these Turbines in Jets,Heli,and even prop planes. BUt i was wondering if anyone have used then for anyother thing???
Old 07-20-2002 | 10:11 PM
My Feedback: (10)
seen a post on the boat section the other day where they put one on a boat. wasnt turning a prop, just using the thrust. Im sure they are working on turning a prop though.
Old 07-20-2002 | 11:08 PM
-JC-'s Avatar
My Feedback: (26)
Default Turbine usage
1. They can be used to heat hot dogs if you don't mind the Jet-A taste.
2. They make great paper weights if you bought one with no factory support.
3. They make a great conversation piece with your neighbors when test run in your drive way at 2 am in the morning.
4. They can make life real interesting when mounted on a skateboard with the throttle stuck in the wide open position.
