A CG/ moment question for Matt / Anyone
My Feedback: (10)
RE: A CG/ moment question for Matt / Anyone
How far forward of the CG can the new nose weight be installed?
EDIT well in any case moving the weight has generated a new moment of 12 inch pounds.
So divide 12 inch pounds by the distance (in front of the CG) that you will be able to mount the nose weight.
Just plug in the distance from the CG to the noseweight and you will have the answer in pounds.
12/(Dist to Nose weight) = Amount of Nose Weight
If it is 36 inches (3 feet) then that is 12/36 = .33 pounds or 5.28 ounces.
