 King Cat Flex plate solution.- >
Old 08-18-2004 | 10:01 AM
Miguel Santana's Avatar
Default King Cat Flex plate solution.-
King Cat's flex plates are sorf of the ink cartrige business to a printer! ....take your time.
My friend Alex Dupuy is kind of lacy posting some sorf of stuff.....but if you have a King Cat and spending your money buying flex plates time to time....lets motivate [sm=punching.gif] Alex to tell you all how he solve his problem
So, Mr. Dupuy,
Are you going to be "come solo" (in english is like "alone eater" [&:])??
...love this forum
Miguel
Old 08-18-2004 | 04:32 PM
Default RE: King Cat Flex plate solution.-
To solve the problem just need to glue 2 flex plates together.
Using only one is extremely weak....[], and with 2 is strong enough to resist any landing error, but at the same time weak enough to a break before damaging the plane.
Is already tested, and they work perfect.
The nose gear does not need this job.
Pictures? are in Alex's camera.-
Any questions.,....welcome.
Regards,
Miguel
Old 08-18-2004 | 06:13 PM
Guest
My Feedback: (73)
does this afect the way the gear mounts ? (lower by the thickness of the flex plate ) ??
Wojtek
Old 08-19-2004 | 08:33 AM
Not at all. Mounting is as before.-
Just remember to make to notches as indicated in the draw....(the notches are only to be make to the botton flex plate..)
Last weekend Alex's King Cat bounce like a bunny rabbit due to a cross wind condition and the flex plates.....still there! [8D]
Alex, did you return from your trip to Siberia?
Good luck.-
